Question about Vizio VU42L 42 in. LCD TV
Vizio vu42L can't get remote channel selection or up/down channel controls on the TV to move to channel 3 or 4 to connect digetal converter to antenna for Sunday NBA game - Help
  • 2,335 Answers
I can help you solve your Vizio VU42L LCD TV problem.
Lets review your remote control.
To select your digital converter for viewing on your Vizio VU42L, we are interested in the top 4 buttons of this picture. From left to right these buttons are TV, AV, COMPONENT, and HDMI.
If your digital converter box is plugged into your TV and is turned on, then you can use these four buttons to select the video source you want.
If you are certain you need to be on channel 3 or 4, then confirm the box is connected to the antenna input on your TV and press TV button. This mode will allow you to change channels normally.
If the box is connected by another type of cable, press AV for rca style connections, or use the COMPONENT and HDMI buttons to select video sources by other cables.
If your TV doesn' t seem to be responding properly, press the TV button above the #1 button to remind the remote you want to control the TV, not VCR, CBL, etc.
I hope that helps.
__________________________________
Vizio VU42L Manual Download
Posted on Jun 06, 2010
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Tip
Vizio VU42L LCD TV Manual Download
Model: VU42L
Have you lost your Owner's Manual for your Vizio VU42L LCD TV?
Would you like a digital copy of the Vizio VU42L LCD TV Users Guide for easy searching of terms and quick reference?
The Vizio VU42L LCD TV manual is available free in pdf format, just follow the link below (& Click FREE):
Download Vizio VU42L LCD TV Manual
I hope that helps.
________________________________________________
on Jun 06, 2010 | Vizio VU42L 42 in. LCD TV
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
Vizio e420 sound problems
1. Press volume up on the remote control. 2. Press the MUTE button on the remote to ensure mute is off.
3. Check the audio connections of external devices (Blu-ray player, game console, cable/satellite box) that are connected to the TV.
4.If you are using an antenna, the signal strength of the channel may be low. Ensure your antenna is connected securely to the TV and move the antenna around the room or close to a window for the best signal.
If you tried the above and still have sound problems, use your menu and check the audio settings to make sure they a right. You may have to reset the audio.
Feb 22, 2013 | Vizio E420i-A1
Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
Dec 28, 2009 | RCA Televison & Video
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Remote to Insignia Digital converter box will not do anything but turn unit on/off, although the light does flash when buttons are push - nothing happens.
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu.
Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna.
On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point.
Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels.
Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4.
When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again.
However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up!
I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held.
The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set.
(continued next page)
Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up.
I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search.
From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Jun 02, 2009 | Insignia Digital-to-Analog Converter for...
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VU42L 42 in. LCD TV Logo
182 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
