I don't understand how to connect my new printer to a computer with a dsl modem.
    Problem Solver:
  • 6 Answers
Tell me Ur printer model number and DSL modem model numbers.
Posted on Apr 10, 2008
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
Trying to access DSL with HP modem
If you mean you're trying to use DSL service with the modem that came built into an HP computer, you can't. That modem is for dial-up Internet service only, or if you want to use your computer as a fax machine along with a scanner or all-in-one printer.
To connect to DSL, you'll need a DSL modem. If you're just getting service, your service provider should have supplied one. (Actually, I think you have the option now of ordering DSL service and not getting a modem if you already have one. Maybe you did this.) The DSL modem has a telephone-type jack to connect to the phone line (same as on the HP modem), but the connection to your computer is through a different, larger, jack usually labeled "Ethernet" or "Computer". If you don't have a modem, you can easily find them for sale. You can buy new ones at retailers who sell computers, and many used ones are available on eBay or on your local Craig's list.
Another possibility is that you already have a DSL modem and are asking how to connect an addtional computer. If this is so, you don't connect the new computer to the DSL phone line. Instead, you need to share the network connection coming from the modem. This is done using a router, which allows several computers to use the same connection either through a cable or wirelessly. The DSL modems typically supplied now have the router built in, with 4 connections for wired computers and wireless capability as well. If your modem is an older one intended for a single connection only, it will have just one network connection. If this is the case for you, you'll need to supply your own router.
Apr 26, 2011 | Computers & Internet
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
I have hooked my di 524 from my DSL cable modem then hooked the two in line to my computer when I hooked up to the computer I have no connectivity why?
OK, if I understand:
telephone----DSL Modem--di 524--computer.
That is what you are supposed to do.
Has any configuration of these devices ever had any connectivity?
1. Is the DSL modem in "Bridge Mode"? That is the first thing I'd check.
2. Are you using the right wires and ports? There may be a DCE-DTE problem. Be sure you have used the wire that came with the DSL modem to hook it to the internet port on the DI-524.
3. What is the state of all the various lights? Do they show that you have valid connections?
4. Most of these devices can be configured with a browser. When you browse them, what do you see?
5. What is windows telling you?
Jan 09, 2010 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
I lost my manual and would like help in connecting to phone jack
Each phone or dial-up modem or fax machine needs a DSL filter attached to the phone line/socket then each phone or dial-up or fax machine is then plugged into this filter.
The DSL modem does not require a filter.
If your fax is part of the computer's modem then a filter is also required on the line-in on the modem.
The instructions for sending & receiving depends upon your system/dial-up modem (the make & model, is it stand alone or a modem adapter on the expansion slot or built-in on the motherboard) and the software you are using. Cannot help you without these details.
Apr 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cannot Connect to the Internet Using a New D-Link DSL-2640B
1. Make sure you have the latest firmware
2. Restore to factory settings first. This helped me with stacked ppp session.
3. Setup your connection according to ISP
4. If you have problem, install Router Commander from www.routercommander.com
5. Setup router to send syslog to your PC
6. Check syslog messages about the clue what's going on
Dec 17, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Printer quit working
try a test page first to determine that the printer has basic abilities.
http://tinyurl.com/6qcpgy
Aug 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
New computer running slow
if you are using dial up, you shud not have a modem.. modem is just for DSL connection
if you have a modem probably you are using a DSL connection
DEFINITION:
dial up - connection using a phone line with internet connection; cannot use fone while on internet
DSL/modem- connection using a modem plugged in with computer and fone line; able to use fone even when on internet.
Jul 10, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
42 people viewed this question
jasbo
jasbo
