Question about Olevia LT42HVi 42 in. LCD Television
Olevia tv just cut off...now no power.... was watchng the tv and it just cut off and now has no power at all...no lights no nothng...does this have a reset switch? Does anyone have any suggestions?
  • 3 Answers
If it is a power supply issue go directly to the Manufacturer FSP USA. Get in contact with the RMA department and for about $20 dollars plus shipping one way you can get your PSU fixed. Turn around time is about 3 to 4 weeks so be patient. Once fixed they send you an e-mail with tracking info. I did this an probably saved hundreds of dollars. The removal of the PSU from the TV is pretty straight forward, 4 connectors and just a bunch of screws. Keep track of the screws and where they go also take a pic of how everything was connected to you can reference to put it back together. One warning stay away from a company called Discount Merchant to try and buy a new PSU the sell refurbished junk that does not work. I tried buying from them a replacement PSU that was DOA and they did not want to refund my money and it was a huge hassle and I had to involve the BBB and my CC company to get a refund. Save yourself the nightmare and go through the Manufacturer. Below is the email contact info incase you cannot find the website.
FSP USA RMA Services" <rma@fspgroupusa.com
Bizznyc.
Posted on Jun 07, 2010
    Champion:
  • 222 Answers
One or more of your Electrolytic capacitors located on your power board had to be replaced
Posted on Jun 06, 2010
"Olevia 65 LCD TV"
8e12bdd8-2e36-4e3d-b2c6-b240db1b35af.jpg I have found a solution to the scrambled / freezing picture for the 65" Olevia LCD T11. At the recommendation of 3D electronics in plano TX, I installed a 200mm fan on the back cover with the air blowing directly on the CPU of the main / video card. I had to cut a whole in the back cover to mount the fan and actually left the bottom panel off to let more air flow. There are some spare 12v terminals on the second power board on board furthest from the main board. I cut the whole out with a jigsaw and had to extend the power wire due to the length required.
Jan 07, 2013 | Olevia Televison & Video
Ok my Tv started to act up it wouldnt cut off when i finaly did get it i tried cutting it on and it would cut on
If it is a Olevia parts are slim to impossible to find depending on model number.
only simple thing to try is unplug set for a while and power back and see what happens.
Let me know what you find.
Mar 14, 2012 | Olevia LT23HVX 23 in. LCD Television
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
Tv power light comes on when i turn on switch in back, but nothing happen when i press button in front Model # Olevia 237 -S11 37 in LCD TV
your on a safe mode energy saver they built then tvs like that for storm and lighting storms ok only push power button one then wait 15 min. then tv should come on.
Feb 14, 2011 | Olevia 237T 37 in. LCD TV
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
The power light (bright blue) on my Olevia 26" LCD burns brightly in my bedroom ALL DAY and ALL NIGHT. Is there anyway to dim it?
Had the same problem and took the easy way out: I cut a small piece of electrical tape and covered the LED. There is no way to dim it.
Dec 23, 2009 | Olevia LT27HVX 27 in. LCD Television
My tv will not turn on the power light comes on
After the power surge , the TV went on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur after power surge on a rear projection are a blown capacitor on power board, a component on ballast board has blown, or a fault on Digital board had occurred.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Dec 07, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
Olevia LT42HVi 42 in. LCD Television Logo
506 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
