Question about MSI K9N6SGM-V Motherboard
Realteck mic problem
My computer configuration is AMD 64 X2 4200+ , Msi K9 Series Motherboard , 2Gb DDR2 ram Etc realtec hd drivers
i tried both microsoft xp sp2 and sp3
my problem is when i record my voice using microphone it records my voice without any problem but when i use the same microphone to chat with any messenger microphone (skype , yahoo , gmail ) doesnt work i.e my voice doesnot reach the destination to whom i am chatting plz help me out
i am really clueless
  • Symbian_King Jun 06, 2010
    I tried all this even though it didnt work i even updated the audio drivers but no change
    i am using external intex sound card with same configuration sound is working fine
  • Symbian_King Jun 14, 2010
    i m using broadband internet connection with 256Kbps speed
  • 4,737 Answers
Well, if it's working when you record sound, then there might be settings related problem with the skype or yahoo messenger etc... Let's get started with the "skype" open your skype - sign in - click on "tools" select "options", on the left pane of the options windows, click "audio settings" and now on the right pane, check the "microphone" settings and verify it's set to "Realtek High Definition Audio", if it's not, do so now. click "Save". You can set the volume manually by uncheking the "automatically adjust microphone settings" and turn up the volume slider. Do the same with the yahoo messenger, but you can't set this before you log in. In yahoo messenger you need to go to the "preferences" - "Video and Voice" from the "Messenger" menu. Also make sure, that "digital input or output" isn't selected.
Good luck. Thanks for using FixYa.
Posted on Jun 06, 2010
  • Lebanon Raingam
    Lebanon Raingam Jun 11, 2010
    Well, can you please let me know your internet connection type and speed?. Let's try another method. Thanks
Is 23.6" ATIV One 7 1TB HDD Full HD Touchscreen PC good for minecraft?
Minimum Requirements:
  • CPU: Intel Pentium D or AMD Athlon 64 (K8) 2.6 GHz
  • RAM: 2GB
  • GPU (Integrated): Intel HD Graphics or AMD (formerly ATI) Radeon HD Graphics with OpenGL 2.1
  • GPU (Discrete): Nvidia GeForce 9600 GT or AMD Radeon HD 2400 with OpenGL 3.1
  • HDD: At least 200MB for Game Core and Other Files
  • Java 6 Release 45
Recommended Requirements:
  • CPU: Intel Core i3 or AMD Athlon II (K10) 2.8 GHz
  • RAM: 4GB
  • GPU: GeForce 2xx Series or AMD Radeon HD 5xxx Series (Excluding Integrated Chipsets) with OpenGL 3.3
  • HDD: 1GB
  • Latest release of Java 7 from java.com
Software Requirements:
  • Minecraft Release 1.6 or newer. Older versions will need to be updated to current versions
  • Please note that some users experience issues playing Minecraft while using a mismatched version of Java for their operating system (32 or 64 bit), while using certain versions of Java 7, or while multiple versions of Java are installed
Apr 23, 2014 | Samsung ATIV One 7 23.6" Touch-Screen...
Here's my issue. Ok i have 2 ram slots. When I have 2 1GB ram cards in the slots the computer registers 2GB ram. When I put in 2GB card and 1GB card, it only registers 2GB RAM. No idea why. I bought...
the issue may be the ram is not the same like a PC100 will not work with a PC300 ram card but if you have the same like a 2GB DDR2 and a 1GB DDR2 it will work unless your computer can only see 2GB of ram then i cannot help you
Jan 02, 2011 | Computers & Internet
My asus m2n32-sli motherboard won't start up; runs for 4 seconds then shuts off. currently hooked up to the mobo: have a 500W power supply; AMD 3300 64 processor; zalman cpu fan; 2 patriot 2GB DDR2...
The only thing i can suggest is remove one of your RAM sticks and see if the machine will boot. I had this problem with mine and it turned out that one of my RAM slots was faulty and would not boot if both RAM slots had RAM in them.
Nov 04, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Which type of ram is supported by msi k9mm-v motherboard
• Supports Dual DDR2 533/667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 2GB.
Oct 28, 2010 | MSI K9MM-V Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Does not support ram over 1gb
Have a look in the BIOS facility, its available at start up, there may be a change you can make there, always try and note down exactly what you have changed on a note pad , or there's no going back, well there's always LOAD DEFAULTS. Good luck, the Yeti
May 20, 2009 | MSI K9VGM-V Motherboard
Is motherboard MSI 915G compactibale with 2gb DDR2 Ram
yes absolutely check for the speed support in fsb
May 08, 2009 | MSI KM4M-V Motherboard
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
Unaible to upgrade RAM
It will only support up to 2GB Ram and the same memory specification
Nov 23, 2007 | ASUS M2N-MX Motherboard
MSI K9N6SGM-V Motherboard Logo
207 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
