Question about Fisher and Paykel GWL11 Top Load Washer
Calls error code at end of first rinse
This machine runs normally but at the end of the ist rinse it gives error code 136. To continue it is turned off and advanced to rinse 2 and finishes correctly.
  • 4 more comments
  • 14mikeblake Jun 06, 2010
    Nope, it runs like a charm with no leaks and the fault has repeated for several months in exactly the same manner.
    Thanks for your interest :-)
    I'm thinking it may be the position sensor, the last time I measured the windings they were 31.6 - 31.6 - 31.7 ohms which seems pretty balanced & Ok to me. I haven't tried a single rise as yet. How would I check for the seized bowl ? everything seems to be working Ok when running.
    Cheers ........... Mike B
    Yeah, that sounds logical. The bowl spins freely and I agree the controller sounds like the best bet. I assume the program is held in an eprom ?? if so can the program be downloaded from any where ?? Can you point me towards some one who does not require body parts for an exchange controller please ??
    Cheers ......... Mike B
    Thanks, I'm in Perth.
  • 14mikeblake Jun 07, 2010
    Ok thanks again for the help.
    If you have some short cuts on checking the position sensor I would appreciate it.
    I assume that one drops the outer rotor off to do that ?? Would that be done with the machine on it's front or do you work from the top ??
    Regards ............ Mike B
  • robert Dec 04, 2012
    Hi Mike B. I have exact same problem as you had- machine stops at end of rinse 1 - with error code 136. but otherwise runs fine and will finish the load normally if i advance it to rinse 2. wWhat ended up being the solution to your problem. (I have already checkd the motor windings and the bearing for free movement) Any advice appreciated. thanks, Rob.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Error 136 means you have''Motor Stall " fault. Now just a couple of questions, has your machine been noisy on spin?does the machine leak water?Please reply with answers and I can help you rectify this fault.
Posted on Jun 06, 2010
  • 3 more comments
  • luisa_sgro Jun 06, 2010
    Thanks for the quick reply. On my service manual it says that the most likely source of this fault is seized bowl or your motor has a faulty phase,"there are 3 phases on your motor.The secondary thing that could be causing your problem is a faulty motor controller.Have you tried select one rinse instead of 2 rinses. Have you tried the traditional wash mode?If you have or can borrow an electrical test meter then we can eliminate the motor as the problem. Please reply back and I can help you further.
    HI just read your posting.!st to check to see if the bowl is seizing open the lid and turn it by hand.If it turns relatively freely then it is not the bearings.The manual did mention position sensor but because your posting said it does the wash ok, the 1st rinse ok and the spin ok I don't think it will be the position sensor.You can check the sensor by removing the motor and checking the sensor for corrosion .If you need help to do this please reply .My best guess on the cause of your fault is the motor controller.If we have this fault at a customers house we 1st change the controller and if that doesn't rectify the fault then we remove the motor and check the position sensor.I know that this is difficult for you to do this because you do not have the spare parts like we do.The only way to test the position sensor is with a meter that is given to us by the company .Try having a look at the sensor 1st and check for corrosion and please reply and tell me what you find.The fault on your machine has some unusual symptoms but hopefully we can track the cause of the fault.
    What country are you in? I know of someone that could help you in Australia.Does that help you all?Please reply and I can supply you with the details.
  • luisa_sgro Jun 07, 2010
    Now the name of the place is called Module Repair .They are in Ringwood in Melbourne.Now if you send it by Express post they will test it and repair it and send it back.It will probably take about 1 week .The phone number is 0398793400.Give them a ring and they will organize everything.IF you need additional help please don't hesitate to reply.Good luck.
    How are ya? Now to get to the rotor sensor to check it, first take off the inlet hoses and lay the machine on its side so you can see underneath.Now you will see the outer rotor with a plastic nut in the center.Undo this nut and pull the outer rotor off. You will see 4x 10mm bolts holding the windings to the base of the bowl.Undo these bolts and remove the windings slowly.Remove the wires to the windings,noting the position of the red ,yellow, and blue wires.Also remove the wiring harness to the rotor sensor. Now remove the rotor sensor from the windings and check for corrosion.Please reply with what you find.Hope this helps ,Good luck.
No water leaks but makes noise on spin
Posted on Apr 24, 2016
My Vabis 2010 washer shuts down during the rinse cycle rinsing normal-soiled items with cold water
FE: Water inlet valve stuck open
Water valve is stuck open and needs to be replaced. The best way to check if the water valve is the problem is to remove the top cover, run the machine to get the water running. While the water is filling, remove the connector to the water valve that is filling. If the water continues to run without the connector, the valve needs to be replaced. If the water stops flowing when disconnected, you may have a control board problem and will need it to be replaced
Jun 23, 2016 | Washing Machines
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
Apr 07, 2016 | Kenmore Elite 45986 Front Load Washer
Hi, I have a F/P intuitive Eco 7kg top loader which has started coming up with fault 136 error after the first rinse. If I turn it off and turn it on I can continue with the rinse 2 and that completes
136. (10001000) Motor Stall
The Motor Control Module has been unable to start the motor. Possible causes of this fault
are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor
Control Module, faulty Rotor Position Sensor or harness.
Primary Source: Wiring.
Action: Measure/check the motor harness, connectors and motor for
discontinuity. This can be done by taking a resistance measurement
between phases of the motor harness at the Motor Control Module
end. If an incorrect reading is obtained the reading should be taken
directly from the stator.
Secondary Source: Motor.
Action: 1) Check free rotation of the agitator and bowl by rotating by hand.
Bearings and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for
water, mechanical damage or corrosion.
Tertiary Source: Motor Control Module.
Action: If the primary and secondary checks pass inspection, then replace
the Motor Control Module.
Jun 19, 2012 | Fisher and Paykel Washing Machines
My washing machine fills very slowly even though there is plenty of water supply. Sometimes the water only dribbles in. The worse time is on nthe rinse 2 cycle. Now it stops when the machine gets to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 01, 2010 | Fisher and Paykel (IWL12)
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
955 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
