Question about Dishwashers
Whrilpool dishwasher hearter problem, water not getting hot and get the7 blicking lights, I can reset it but dose not stay reset. Also I noticed the water level is not over the element, is this normal or is that causeing my problem?
  • 523 Answers
The door switches can be bad but make sure the door is shut from the center
Posted on Jun 06, 2010
The water in my dishwash is not getting hot dose the cord that's in the bottom of sopose to get hot?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jun 16, 2011 | Dishwashers
Hi. my dishwasher finishes its cycle but the dishes are cold and wet (and very poorly cleaned). it seems that the water is not getting hot. what might be causing this?
First check your hot water hearter and see if its working right. If so try cleaning the jets in the dishwasher. Over time the will clog with particals and restrict water flow. Its easy to take them off. just unscrew whatever is holding the jets in and putting it back togeth should be just as easy.
-Personal expriance.
Mar 09, 2011 | Dishwashers
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
Hotpoint dishwasher swd6o
all dishwashers don't heat the water themselves. the water supply should be tied into the hot water line under your kitchen sink.
Sep 18, 2009 | Dishwashers
How do i reset the dishwasher when light is flshing but not run
Hi
To reset the Dishwasher when the light is flashing press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water your incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this insures your unit fills with hot water and not cold.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
WATER IS NOT HOT
Hi mac3493,
I'm Harvey the Master Plumber.
Your problem is: WATER IS NOT HOT
The hot water for your d/w comes directly from your hot water heater. Sometimes the pipe length from the hot water hearter is very long, so when you turn on the d/w it's filling up with the water that 's been sitting in the water lines. By the time the hot water gets to the d/w it's already full. All is not lost. When you're ready to turn the d/w on, first turn on the kitchen sink faucet and let it run till the water is hot, then turn on the d/w.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Whirlpool Dishwashers
Dose not finnish washing and starts bleeping and start light keep flahing. water is hot by have not dryed
Neighbor had a similar problem with a GE dishwasher except it wouldn't start and kept beeping when door was closed. So the door was left closed, and while it was beeping, turned off the circuit breaker that fed power to it. Waited about 30 seconds, turned circuit breaker back on, bleeping had stopped, dishwasher was reset. Normal and heated dry were already selected, (since I had tried pressing those two before all this to force a reset), then pressed start and it ran again. Hope this might help you.
Jul 25, 2008 | Whirlpool Dishwashers
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
