Question about RCA 35V432T 35" TV
No pix/sound, just high pitched whistle
When plugged in, tv makes high pitched whistle. can't turn on or off. no sound or picture. rca 35" tube tv.
  • RCA Master
  • 8,457 Answers
Ur tv the high voltage it dead,the FBT,the flyback transformer.The big black block of plastic with a red wire with a black cap that hook up to the CRT(tv tube) is dead.The FBT,flyback transformer needed it to be replaced to solved this problems.Call the shops,take estimates for the best deal to do the repair.This is one of the main part of the tv to put HV in CRT(tube tv).It pretty hard to find this FBT these day,because of the discontinue of making of Amalog tvs.
Posted on Jun 06, 2010
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
I have a RCA projection TV. The picture and sound are fine. After the TV is on for a bit it starts a highe pitch whistle. The picture and sound continue to be fine. What is the problem and what can I do to...
Most likely the color wheel is starting to go bad adn when they do they get a high pitched whine sound coming from the bearrings on the wheel. Might want to look at getting a replacement before it quits. When they die you can't watch your tv till it is repaired.
thanks
Jul 22, 2011 | Televison & Video
Rca tv makes hi pitched whistle when plugged in.
You have a bad horizontal transistor and a possible bad flyback transformer! These two components are indicating a short in your horizontal deflection. Thanks for asking!
Jun 06, 2010 | RCA 35V432T 35" TV
10-year-old 32" RCA PIP TV just blinked off one morning after about 30 minutes. It makes a continuous high pitch sound, and the on/off switch is completely unresponsive. I assume this is a picture tube and...
It's not the picture tube(especially if image was good b4 it went dead). The high pitch noise is the power supply whinning because it's shorted or overloaded. I just fixed one of these sets - replaced the horiz. o/p transistor and flyback estimate around $120.00-$160.00
Oct 24, 2009 | RCA F32650 32" TV
High pitch sound coming from circuit board, cannot
First, you will want to isolate the problem. Is it feedback from an AC outlet you have it plugged into? Is it a recent noise that just started with no changes to Tv or its environment, then you may want to consider that a circuit is going and decide if it is worth repairing, You should find that type of fix at a shop for under $100
Sep 27, 2009 | RCA F35317 35" TV
Same problem, high pitched noise over regular sound and no pictur
No guarantees with this diagnosis. But it sounds like an HT ( high tension) leak This is often caused by the lead becoming partly unplugged ( being bumped or moved) and because of dust buildup it arcs making a high pitched hissing whistle.Ther lamp may also have been affected by the HT leak. The safest option for you is to call a service technician to it, as opening it up could cosntitute a a danger to the unskilled.
Aug 12, 2009 | RCA HD56W58 56" TV
RCA F36650 Television . . .
It can be repaired. It sounds like a bad high voltage transformer or something in that circuit. I would take it to a TV shop and ask for an estimate. It might be costly to repair.
Apr 16, 2008 | RCA F36650 36" TV
Television won't power up
It sounds like the high voltage circuit got damp and arced. This arc caused the horizontal output transistor to short.
You might try replacing the output transistor if you're experienced in this type of repair. If not then you need to take it to a repair shop.
The "whistle " you're hearing is the power supply indicating that it has a short on its load. When the power supply has an over load (short) its frequency drops down when your ear can hear it oscillating. This type of power supply is a switching power supply normally operating a several thousand hz(cycles) which is out of range of human hearing.
Stargazer
Mar 15, 2008 | Televison & Video
No picture, buzzing sound
It sounds like the horizontal output transistor may be shorted....Can you feel any static charge on the face of the pix tube?
Nov 15, 2007 | Toshiba 36A43 36" TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
RCA 35V432T 35" TV Logo
601 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
