Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Problem involving Nintendo Wii and MAC address
I have recently got a Nintendo Wii, and tried to connect it by enabling the MAC address. I think what I have done is only allowed that to connect (despite this it still doesn't work) and now I can't get internet at all through my wireless router. I have plugged my computer in directly to the modem and tried accessing http://192.168.2.1/ but it doesn't load. Can someone please tell me what to do.
Try restoring the router to factory defaults. With the router plugged in, insert a pin to press the reset button. Hold it for 10 seconds then release. Your router should be restored to factory defaults then you can set it up again.
Posted on Jun 05, 2008
What is error code 209600
To solve this error :
This error is caused by an issue with the Wii console being unable to connect to your wired router.
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
Log on to your router by using the default IP address and check if MAC filtering is on or enabled, which is usually under Security. If MAC filtering is on or enabled, add the Wii console's MAC address as an approved MAC address.
Oct 24, 2010 | Nintendo Wii Console
Error code 51330
Hello murz42
This error code is generated when the Wii console is unable to connect to the access point.
First of all, check that your router is compatible with the Wii www.nintendo.co.uk/NOE/en_GB/support/wii_support_5251_8071.html?id=8072
Are you using WEP or WPA security on your router? Log into your router using the default IP (if you don´t know this, or how to obtain it, consult your routers manual).
If you are using 64-bit encryption, the WEP key is a 10-character key consisting of numbers or the letters A - F. If you are using 128-bit encryption, it will consist of 26 characters. The WEP key must be hexadecimal. This means that it consists of the numbers 0-9, the letters A - F. It cannot consist of any special signs or letters. If you are using WPA, the Wii is compatible with the following types: - WPA - PSK (TKIP) - WPA - PSK (AES) - WPA2 - PSK (AES)
Next, check if your router is using MAC filtering. You still need to still be logged into your router. Find the section for MAC filtering, which is usually located under a "security" tab or something similar. If the MAC filtering is "on" or "enabled", enter the Wii´s MAC address to the list of approved MAC addresses. To find this, go to the Wii Channel menu, select "Wii settings" - "Internet" - "Console Settings". The MAC address is displayed on the first line.
Hope this helps. If you require any further help, please don´t hesitate to ask.
Good luck
ajblaj
Sep 06, 2010 | Nintendo Wii Console
Trying to connect my Wii to recieve netflix. Error code 52030 appears. Not a computer wiz
Okay, that error code usually is applied to your wireless security. Here's a website that should help you fix it.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
The site also has information for Contacting Nintendo if you need someone to help you walk through it :)
Aug 12, 2010 | Nintendo Video Game Consoles & Games
Cannot connect to internet error code 51330 is showing
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
Need more info? Check Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Setting up wii wireless
log on to the router and get the right wireless key if the router has multiple solts to enter wifi key select to 1 if the above is right its its to do with mac filterting if the mac filtering is enable u must add wii mac address to allowed list if the mac filter is disabled no probs try changing the channel set to 11  set the wireless to mixed or b/g mode try manul set up of wii try turning off the router and wii  then confuguring again hope this will fixya
Nov 02, 2008 | Nintendo Wii Console
Nintendo wii
do everything you did before but just before you click ok for the 'test connection' on the wii console go to the livebox and press the 'number 1 button'.now click ok to test connection on wii.provided the 26 digit number is correct you should now get connected
May 25, 2008 | Nintendo Wii Console
I have a wi-fi that i cant get to work for my wii
please elabourate on your problem so we can attempt to help.
Mar 08, 2008 | Nintendo Wii Console
The internet on my wii
· Here is a Video on how it is done, if you have done this... i believe it would be the settings on your computer.... are you able to set settings on your switch?
YouTube - How to setup a Nintendo Wii USB Lan Adapter (Remix version)
Feb 10, 2008 | Nintendo Wii Console
Wii Wi-fi Internet Connection
A Wii has a macc address just like any other networked element. Do you have mac-address filtering turned on? If so, you may have forgotten to enter your Wii mac address in the list.
Hope this fixes your problem!
Jan 03, 2008 | Nintendo Wii Console
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
55 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
