Question about GE WBVH6240F Front Load Washer
GE WBVH6240F Front Load Washer makes a lot of noise when spinning; sounds like knocking. When I look at where the belt is it looks like it is bent. I don't know if it is a bearing or the whole piece that I need to replace or if it is that at all. The washer is going on 5 years old.
    President:
  • 1,554 Answers
Wiggle the drive pulley to check if you hear a knocking sound from the bearing signifying that it is worn. The bad news is, the bearing is molded into the rear outer tub. This requires the replacement of the rear outer tub with the bearing on it and costs about $400.
The spinner support assembly, also known as spider assembly, is broken if the knocking sound is coming from the inside of the outer tub. The thing is, you are likely to have a new washer instead of replacing the spinner support assembly since it normally comes with the stainless drum as an assembly and costs about $500 plus the labor cost.
In either case, the complete tear down of the washer is necessary to do the replacement. Call up service if you are not handy enough to perform this kind of repair. Please let us know if you have determined the real score and opt to repair the washer yourself.
Posted on Jun 06, 2010
BELT BURNT FRAYED THEN BROKE, SOUNDED LIKE BEARING NOISE
It may be a garment stuck in between the inner drum and the outer shell
Aug 31, 2012 | GE WBVH6240F Front Load Washer
DURING THE SPIN CYCLE THE WASHER STAR KNOCKING.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 20, 2011 | GE WSXH208A Front Load Washer
My drum feels like it is coming loose. is their bolts to tighten it up inside?
hello if it's really loose the bearing are gone does it make scraping and knocking noise when spins if yes this is the problem hope it help
regards
shaun
Jan 03, 2011 | GE WBVH6240F Front Load Washer
Washer is not adequately spinning cloths--too wet unit tends to be easily overbalanced--we have repeatedly adjusted leveling feet
check the berring!!! spin the machine empty by hand, and you might hear a slight or heavy scrapping noise.
Mar 09, 2010 | GE WBVH6240F Front Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Washer wont spin
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
Dec 13, 2008 | GE WBVH6240F Front Load Washer
My Bosch Nexxt Essence front load washer is making a knocking and squeaking noise during the whole spin cycle. It sounds like it's coming from the drum mounts - what should we do?
My Bosch Nexxt Essence front load washer will not drain. I changed the lint filter, and insured that the drainage hose was free of debris. I removed all the wet clothes, wrung out the excess water, and redistributed the clothes. Still, no draining or spinning. Initially there was a humming sound, but now there is no sound at all when I try to restart the drain or spin cycles. All the lights are appropriately "on".
Apr 13, 2008 | Bosch Washing Machines
GE WBVH6240F Front Load Washer Logo
139 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
