Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
Fg2000tc tried a 1000 watt jack hammer but overload alarm came on what to do
  • 593 Answers
Your gen. is a 2000 wt max 1000wt running out put. Means it will start your jackhammer but will not maintain the wattage to run it long. You are using the max it has to put out. So let me try to explain - 2000 watt max output works like this - We will use a fan as an example. A fan sitting still and not turning takes more amperage/watts to start. that is called lock rotor amps. So lets say the fan is a 1000w to run. 2000w start the fan turning then it takes 1000w to keep it turning. Your gen. can start the fan but not keep it running it is using all it has to put out, now if that fan only uses say 750 w running watts you have some head room to keep it running with out things getting hot. Hope this is clear as mud.
Posted on Jun 06, 2010
Testimonial: "good answer thanks 4 help"
My schwinn stealth 1000 shows I have power but when I twist my throttle nothing happens?
Melted means overload, blown means a short, possible causes-bad connection on battery leads, motor brushes worn, shorted wiring in motor or bad bearing, brake dragging on wheel, motor controller going bad. Check it with wheels off the ground , try to isolate what is binding , causing overload on the motor.
Jun 03, 2015 | Schwinn Motorcycles
How do you stop generator from stalling under load
As you have not provided me with the information I requested I'm going to have to take a few guesses here Bob. You could be overloading the generator. You can't run a 10,000 BTU air conditioner off of a 1000 watt generator. You need to look at your load, (what you are trying to power), and determine how much power it needs. Almost everything has a tag somewhere on the device. Most don't give watt requirements. But they do tell you, how many amps the device pulls, as well as the voltage the device needs. So you need to do some math here. Volts X Amps = Watts. So if we have a 120 volt device, that pulls 15 amps, we need 1800 watts to power it. But it gets a little more tricky than that. Motors are often rated at what they pull while they are running! But it can take two or three times more power to get them started. Example... A motor rated at 10 amps, using 120 volts will be 120 X 10 = 1200 watts. But it could take 2400-3600 watts to get it running. So in theory a 3000 watt generator may die before it can start that load. Heating elements are also power hungry! Let's say you have a small 800 watt generator, and your just trying to run a simple coffee pot! Well the heating element in a typical coffee pot pulls 1000-1500 watts. A hair dryer or microwave oven rated at 1000 watts, is the power they produce, not the power they consume! So a 1000 watt microwave may pull 1600 watts of power to run. Most non US generators are highly over rated as well. I certainly would not trust a Harbor Freight 3000 watt generator to actually put out 3000 watts of power. Not that they are bad units, I would expect their numbers to be under PERFECT conditions. Temperature, humidity and altitude also play a part! Your 3000 watt generator is going to put out more power at 50 degrees, at sea level, than it is at 7000 ft in the mountains at 100 degrees. So my "guess" Bob, is that your just asking more from the generator than it can produce. Picking out a generator is not as easy as it looks. "Hey that one is $1000 and this one is $300! They both make power! What's the difference". The difference is what do you need to run! "Heck I'll just get that 50,000 watt unit"! Yeah you can do that too, but you will never use that much power, and you will burn way more fuel than you need to. My other "guess" is that you have a governor issue on the engine. As load increases the gov will throw more throttle to the motor. My generator has an option to run full speed or on the gov. So it will idle and burn less fuel while I am hammering in a nail, then go to full power when I trigger a saw connected to it. Lot's of factors involved here Bob.
May 30, 2014 | Generac Electrical Supplies
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
My Jack Hammer JH600 1200 Watts Amp will not turn on what could be the problem?
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some mo
May 22, 2013 | Microwave Ovens
Do you have to grease or oil anything on the bosch jack hammer
Grease bosch order nr 1 615 430 001 225 ml for 1 service OR 1 615 430 007 1000 ml for bulk repair.
Mar 16, 2013 | Bosch Brute Breaker Hammer 11304
Grundfos cue inverter drive with a pump CR45-2 is showing an alarm code of 16/47 and 16/1 we cannot figure out what is tripping this alarm how can we trace this down and get corrected
this caused when you dont have rt guage cable to provide correct voltage,what wattage of inverter you have,if it is a 1000 or more you may have to have a 6 guage cable or 4 if more than 1000 watts
Jul 07, 2011 | Electronics - Others
M/n cpi 1575 I've had my inverter installed in my
it indicates an overload situation
not enough information provided as to voltage supplied to the inverter and the voltage of the grinder
examples are for 110 volts ac with a current draw of 4.2 amps the wattage is 462 watts or for 240 v ac with 4.2 amps the wattage is 1008 watts assuming that it is 240 volts and the inverter has a maximum ate of 1000 watts then it is overloaded and circuit protection is cutting in
check the wattage of the inverter and the wattage of the ac units you use and if there is not a 25% difference in favour of the inverter then it is an overload situation
Jul 27, 2017 | Cobra ® Power Inverters
Hi, When my GE jvm1650bb microwave starts, it begins to work and then blows the fuse in the house. Does this every time, the circut is not overloaded. Is their a part that went bad that I can replace?
Try your oven on another circuit in your house. It is curious that your oven doesn't blow its own fuse before the house one. If it doesn't blow the fuse in the "new" circuit, check to see what is really on the kitchen circuit. It might, in fact, be overloaded. Good luck.
Nov 28, 2009 | GE JVM1650 1000 Watts Microwave Oven
Will a SONY XPLOD XM1652Z 2 CH 1000 watts hold two 12in subs?
should do easily though you may need to employ the use of a cross over just incase something goes pop and burns you're car out when you park it after you've been hammering the subs.
May 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
174 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
