Question about Samsung SGH-L700 Cell Phone
BUTTON DEF . PQRS HAS TO BE PRESSED INTERUPTINGLY TO WRITE A MESSAGE SOME TIMES . I VISITED SEVERALS TIMES THE SERVICE CENTER ALCON AT CHANDANAGAR , HOOGLY W.B, BUT THEY WERE UNABLE TO RECTIFY. THE PRODUCT IS WITHIN WARRANTY PERIOD . SO I REQUESTED THEM TO CHANGE MY SET ALSO TO THE COMPANY SAMSUNG . BUT THEY SHOWED A NEGATIVE REPLY .
    President:
  • 1,561 Answers
Is this the design for the phone that PQRS as to be press before you can write text? if no, then it means it is a factory problem, it could be a software problem that it is only samsung that can fix it because the phone might have problem.
Since the phone is still under warranty, i will advice you press further on samsung to help fix the problem or to replace the phone, to go about this, you must not let them know you have taken the phone to any repairer shop.
I believe and advice you keep pressurizing them for a fix by them or a replacement the phone.
Take care.
Posted on Jun 06, 2010
As the letters in the user guide are so small for those with bad sight, please send by email a copy in larger writing
2 ABC 3 DEF 4 GHI 5 JKL 6 MNO 7 PQRS 8TUV
9 WXYZ
YOU WILL HAVE TO SEARCH THE INTERNET TO FIND OUT ABOUT PLAYBACK /FF/REW STOP
Mar 03, 2015 | Lands Phones
Sharp AR-M205 Calling for Maintenance. How do yuo reset?
1. unplug the printers power cable it resets ALL printers
2. Once you have it unplug the power cable back in and turn it on make sure it's plugged into the computer.
3. you may need to uninstall and reinstall any software and drivers that came with the printer
4. download and install all the critical updates and service packs for your operating system
5. download and install any updates for your printer from the shap printer driver site
Az.
Sep 17, 2008 | Sharp Office Equipment & Supplies
Tip
Ford-Lincoln service light 1988-01
LS
2000-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the STATUS control to access the System Check mode. Press the RESET button to display OIL LIFE _% RESET FOR NEW. Press and hold the RESET button until OIL LIFE IS 100% is displayed.
Mark VIII
1993-97
When "CHANGE OIL SOON" or "OIL CHANGE REQUIRED" is displayed on the Message Center, turn the ignition on. Press and hold "OIL CHANGE RESET' or the "RESET" button until "OIL LIFE RESET TO 100%" is displayed on the Message Center.
Continental
1989-94
When "SERVICE" is illuminated, on the Message Center, press the "SYSTEM CHECK" button on the right of the display. Then press the "RESET" button. The "SERVICE" symbol and mileage will start to flash. Next, press the "SYSTEM CHECK" and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
Continental
1988
When "SERVICE DUE" is illuminated on the Message Center, press the "CHECK OUT" button located below the display. Then press the "RESET" button. The display should now read "SERVICE DONE?" Next, press the "CHECK OUT" button and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
on Dec 07, 2009 | Ford Lincoln Continental Cars & Trucks
Tip
Ford service light procedure 1994-01
Windstar
1999-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the message center, press the SETUP control to access the System Check mode. Press and release the RESET button until IF NEW OIL HOLD RESET is displayed. Press and hold RESET button until OIL LIFE SET TO 100% is displayed.
Windstar
1997-98
To reset "CHANGE OIL SOON/OIL CHANGE REQUIRED" message on the Message Center, press "RESET" and "SETUP" controls at the same time. "OIL LIFE % HOLD RESET NEW" will be displayed. Press the "SETUP" control to access the System Check mode. Press "RESET" to start the system check. Press and hold the "RESET" control. Press "RESET" and "SETUP" to reset the system to 100%
Explorer,
Mercury
Mountaineer
1997-01
To reset the oil life feature on the Message Center, press and hold the "OIL CHANGE RESET" button until the system counts down (about 5 seconds). The Message Center will display "OIL LIFE RESET TO 100%"
Probe
with Analog Dash
1989-92
When "SERVICE" is illuminated on the Vehicle Maintenance Monitor on the overhead console, press the "SERVICE INTERVAL RESET" button located directly above the light.
Probe
with Digital Dash
1989-92
Probe
with Digital Dash
1989-92
When "SERVICE INTERVAL CHECK" is displayed is displayed on the far left side of the instrument panel, press the "SERV OFF" button, located on the speed alarm keyboard, until three tones sound.
Thunderbird,
Mercury Cougar
with System Scanner
1986-88
When "SERVICE" appears on the Diagnostic System Scanner, press the "ODO SEL" and "TRIP RESET" buttons simultaneously. The "SERVICE" message will go out and three short beeps will be heard when the system is reset.
Thunderbird,
Mercury Cougar
1989-94
If "CHANGE OIL SOON" or "NOW" is indicated on the Monitor, turn the ignition on, but do not start the engine. Within 16 seconds, insert a paper clip into the cavity to the left of the display and depress. The display will flash; when it stops, the system is reset.
on Dec 07, 2009 | Ford Windstar Cars & Trucks
Windows security center will not turn on
The role of the Security Center component in Windows is to notify you of security-related events.
Generally, the Security Center will prompt you when one of your security programs is out of date or disabled.
If this component is disabled, Windows will no longer be able to alert you of these events. Additionally, if disabled, you will be presented with the option to turn it back on.
If you receive a message that states it cannot be started after pressing the "Turn on now" button, you must enable the dependency service.
Press the "Windows" and "R" keys simultaneously on your keyboard.
Type "Services.msc" in the Run box and click "OK."
This loads the Windows services tool.
Double-click "Security Center" to load the properties for this service.
Click the "Startup type" drop-down menu and change from "Disabled" to "Automatic." Press the "Apply" button to save the change.
The service will automatically start the next time you load your computer.
You may force the service to start without rebooting, by pressing the "Start" button.
You should now be able to press the "Turn on now" button in the Security Center without error.
Hope this helps
Nov 03, 2012 | ASUS Computers & Internet
Tip
Cadillac service light 1989-01
Eldorado
2000-01
Turn the ignition to ON. Press the TRIP button on the driver information center (DIC) switch to view various menu choices and stop on OIL LIFE REMAINING. A message will display the percentage of oil life remaining. Press and hold the RESET button on the DIC switch for at least 2 seconds. A message will display the percentage of oil life remaining as 99 percent. The engine oil life monitor is now reset. Turn the ignition OFF.
DeVille,
Eldorado
1999
To reset the service Oil Life Indicator, display the
"OIL LIFE LEFT" message by pressing the "INFORMATION SKIP" (skip info) button. Press and hold the "RESET NO" (no info reset) button until "100% OIL LIFE" is displayed.
Deville,
Seville
2000-01
Turn the ignition to ON, Press the INFO button on the driver information center (DIC) to display ENGINE OIL LIFE. Press and hold the INFO RESET button on the DIC until the display reads 100% ENGINE OIL LIFE. The engine oil life index is now reset. Turn the ignition OFF.
Deville,
Seville,
Eldorado
1997-98
Display "ENGINE OIL LIFE" by pressing the "INFO" button. Press and hold the "INFO RESET" button until the message shows 100.
All Models
except
Fleetwood
1994-97
Press the "INFORMATION" button until "OIL LIFE LEFT" is displayed. Press the "RESET" button until "100" or "0.0 OIL LIFE LEFT" is displayed.
Fleetwood
1994-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds.
All Models,
Seville,
Eldorado
1993,
1994-95,
1994-95
The automatic transaxle message can be reset through the following procedure. If "CHANGE TRANSAXLE FLUID" appears on the Information Center, press and hold the "OFF" and "REAR DEFROST" buttons until "TRANS FLUID RESET" appears.
DeVille,
Fleetwood
1991-93
When "CHANGE OIL SOON" light is illuminated, press and hold the "RESET" and "RANGE" buttons on the Fuel Data Center for 5 to 60 seconds. When the buttons are released, the light will flash four times if it has been reset. If the light comes back on for more than 5 seconds, repeat the procedure.
Allante
1989-93
When "CHANGE OIL SOON" appears on the Driver Information Center, press the "RANGE" button until "OIL LIFE INDEX" shows on display. Then press and hold "AVG SPEED" and "RESET" (or "RANGE" on late models) buttons until display shows "100".
Seville,
Eldorado
1992-93
Press "INFORMATION" button on the Driver Information Center until "OIL LIFE INDEX" is displayed. Press "STORE/RECALL" until "OIL LIFE INDEX" resets to 100.
Seville,
Eldorado
1989-91
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center, press "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
on Dec 07, 2009 | Cadillac Eldorado Cars & Trucks
The ink absorber is almost full.
The ink absorber is under the print engine and covers the whole bottom of the machine. It is 5 inches wide and over a foot long. Did you really clean this part? You can't reset the error code without getting into the diagnostic program which only a shop can do...
Jun 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How to knock off servise warning light on a renault laguna
Press the button on the end of the wiper stalk untill you see the message service due. at this point press & hold the button for up to 30 sec, the service message will then flash & will after several flashes reset its self to the next service. If you miss the message just press several times untill the service message comes round again.
Jun 12, 2009 | 2000 Renault 181
Sharp copier/printer AR-336
do the folowing to access service mode
enter,the folowing keys Program, Interupt,Clear,Interupt
once the service screen is displyed .enter the number 14 than press the enter key
Nov 27, 2008 | Office Equipment & Supplies
Samsung SGH-L700 Cell Phone Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
