Question about ATN Aries 390 Paladin Weapon Sight
My Aries 390 has been in my gunsafe for four months, it worked when I put it away last year. This year I turned it on and only the red cross hairs appear, the screen is black, any idea how to fix or what could have happened?
2 Suggested Answers
  • 15 Answers
SOURCE: Aries 390 Paladin
Tubes can go without warning, but power supplies usually do. Get someone to check if PSU takes a current at switch on and then measure the HV.
Posted on Nov 29, 2008
How to date my daisy model 1894 bb gun
under the model no. the reg. no has like k for first letter, this stands for month 10 ,the next 2 no.s stand for year like 85 then the last no.s stand for the amount like its the 8,540th gun put out. thats what i was told hope it helps
Oct 24, 2011 | Simple Shoes Daisy 4x Bb Gun Air Rifle...
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
There is not picture its just vioce
Battery OK, IR light up, no green image on the intensifier image tube, correct! What type of voices are you hearing? Give ATN Aries 390 two Zolof and wait two day, just kidding!!! The noise is a crackling, high freqencey hum, popping, etc. Also remove the eye lens, it screw off, then remove the scope to someplace where it semi dark. Turn it on and observe the 18mm white plate and see if it turn green---no green---no look see---no image intensifier tube, it dead that is the mage tube. stewbison.
Mar 15, 2011 | ATN Aries 390 Paladin Weapon Sight
When is best time to sight in ATN 390?
At night. You can sight in the 390 during the day in simi-darkness with a day light lens cover over the front of the scope. (the snap cover has a small hole in the center for look see during the day) 50 foot room with a target, bench rest and a rifle vise. You'll also need laser bore sight Figure you rifle ammunition ballistic and how many yards before it starts to drop. Set the 390 reticle to the red do on the target one or two inch above. Dead center set up will give you about two hundred yards on center... approx. Now you know this is a static test or sight in. During night because of some distortion and noise from the scope. stewbison
Feb 17, 2011 | ATN Aries 390 Paladin Weapon Sight
Does it take some type of gel under the lights, the colors are a little blurry
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
What is the pin# for the Plantronics Explorer 390. I just purchased this new and threw away the whole packaging.
lorrett143
The pin is 0000 for the Plantronics Explorer 390. I also have included the instructions if you need them.
To put the headset into pairing mode:
1 - Start with the headset powered off.
2 - Press in and hold the Call Control Button (on/off button) until the headset flashes red, blue, red, blue.
3 - Tell your phone to "Find the new Bluetooth device" (see the User Guide or call a local phone store).
4 - If the phone asks for a User Code or passkey, enter 0000 (four zeros).
Issken
Feb 08, 2010 | Plantronics Explorer 390 Bluetooth Headset
Four wheel drive won't engage
Try to rock it by putting it into D an R it works for my truck.
Feb 18, 2009 | 1994 Ford F150 Styleside Supercab
Aries 390 Paladin
Nov 12, 2008 | ATN Aries 390 Paladin Weapon Sight
Nv sight dead
No more lights steady type: Aries 390 Paladin, light guide only focus.
Mar 27, 2007 | ATN Aries 390 Paladin Weapon Sight
ATN Aries 390 Paladin Weapon Sight Logo
110 people viewed this question
Top ATN Optics Experts
Bill Boyd
Paul Woodward
Tony Parsons
Tony Parsons
Are you an ATN Optic Expert? Answer questions, earn points and help others
