Question about Fujitsu Siemens LifeBook E2010 Notebook
Hello my fujitsu e2010 jusr stop working it will
Hello my fujitsu e2010 jusr stop working it will not boot shows battery and the hard drive indecator just flash the cooling fan comes on and thats it
    Sergeant:
  • 356 Answers
Hi. Try to remove the battery, unplug the ac adapter and press/hold the power button for 10 seconds then plug the ac adapter in. do not put thebattery back in yet. turn the computer on and see what will happen.
If nothing happens, your motherboard needs to be replaced.
Good Luck!
Posted on Jun 06, 2010
How to replace the keyboard of Fujitsu Lifebook E2010
Below is a video to replace the keyboard on another model Fujitsu laptop. The method should be the same.
Jan 05, 2012 | Fujitsu Siemens LifeBook E2010 Notebook
In a Sony vaio the Fujitsu hdd reports an error and is unable to boot. When I hook the hdd up to a different system the files are accessible and usable. (ex. You can play music that's on it). How can I...
When you connect the Fujitsu to the Sony laptop. use disk management utility to see how the how the sony is characterizing the Fujitsu. If you can access the files on the Fujitsu from another computer, the Fujitsu is not faulty. Your connection with the Sony is the problem. Disk management utility instructions are listed below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
I hope that this information is helpful, if so, please rememeber to leave positive feedback.
Thank You,
Brian
Feb 13, 2011 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
Working on a friends laptop, the hard drive shows in bios but when trying to format it with windows xp it says there is no hard drive installed, it booted to the welcome screen before
Are you using the Fujitsu-supplied Windows XP Installation Media, or a "generic" Windows XP CD-ROM?
The "generic" version may be lacking the device-drivers for the SATA disk-drive,
and therefore cannot "find" the disk-drive.
Nov 07, 2010 | Fujitsu MHW2060BH 60 GB SATA Hard Drive
I have an e2010 fujitsu lifebook. When I turn the computer on, it says windows didn't start properly and wants me to select safe or last known good and so on...however none of them will work. The computer...
Insert your Windows install CD and boot from it. When it asks you to select either install a new copy or Repair current OS. Select current OS, you might lose some data but it might fix the starting problem.
Mar 14, 2010 | Fujitsu Siemens LifeBook E2010 Notebook
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
My 10 gb fujitsu hard disc is not detected by ide and usb port
Hello, If this is an external drive and your using Windows plug the drive in and open Control Panel, then open administrative tools,next, open computer management then on the left side under storage open disk management. Your drives should show up here identified as letters, C: - D; etc. If your new drive shows up here click it or right click it to see if it needs to be initialized,if it does do so. Go back to My Computer and see if it shows up there.
Dec 12, 2009 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
I have a fijitsu lifebook E2000, in order to install a hard drive, there is a special adapter that goes on the IDE interface on the hard drive that allows the hd to connect to the motherboard. do you know...
Ask your manufacturer Fujitsu for that special accessories so that what you can purchase is 100% compatible to your device. You can browse the website for info as well.
Nov 25, 2009 | Fujitsu Siemens LifeBook E2010 Notebook
BLUE SCREEN STOP ERROR AND NO HARD DRIVE SHOWING
Sorry, but there's no real way to troubleshoot this without actually having the device. The problem you describe could be anything from a simple corrupted system32 driver or MBR (master boot record), to a hardware failure. The simplest thing you could try is to boot from your OS installation CD/DVD, reinstall the OS, and re-install your applications. Next would be to re-format the boot drive and restore your data from your most recent backup. Sorry I don't have better news for you.
Aug 16, 2009 | Fujitsu Siemens LIFEBOOK S7010D...
Hard drive does not hold windows xp
When you install windows and it's shows you 1 or 2 partitions, it's asking you if you want to DELETE partition, - say yes and delete all partitions you have, so when you done deleting all you'll have ~ 79GB of UNPARTITIONED spase. Only then, format as NTFS and install Windows.
Apr 05, 2009 | Fujitsu Computers & Internet
Fujitsu Siemens LifeBook E2010 Notebook Logo
332 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
