Question about Norscot Group 1/50 Kenworth W 900 W/Lowboy
Have a kenworth that is blowing white smoke and using antifreeze
We have a 900L kenworth that is using a LOT OF ANTIFREZE AND IS BLOWING white smoke through the stacks and is not loosing power
    Problem Solver:
  • 19 Answers
U have a blown head gasket or a busted head
Posted on Aug 15, 2010
  • Shane Wilson
    Shane Wilson Sep 07, 2014
    Pressure test the cooling system and check the oil for coolant. Most likely it's the oil cooler, one of the injector cups or one of cylinder liners is leaking.. Due to you not losing any power.
Car blowing white smoke out of tailpipe. car overheats quickly when driving. car shutters when still
im afraid you have a blown head gasket white smoke is cause by antifreeze burning in the cumbustion chamber causing white smoke
Aug 26, 2011 | 2000 Daewoo Lanos
I have a 1991 suzuki gsxr 750, Just changed sparq plugs, and bike Is blowing white smoke.What might be the problem?
White smoke is most likely antifreeze. Blown head gasket most likely. Does the exhaust smell like antifreeze?
Aug 01, 2011 | 1991 Suzuki GSX-R 750 M
If got a 94 Cherokee with a straight 6 from 98 in it, i replaced the oil pump thermastat housing, and coolant lines, after i sarted it after doing the oil pump it started and was real loud running at...
White smoke usually indicates antifreeze. But depending whether you spilled it in the exhaust system when you changed engine it should eventually disappear. When running loud do you mean the exhaust system is not hooked up. Was the throttle stuck open or is there a vacuum line off
Jan 19, 2011 | Jeep Cherokee Cars & Trucks
Car is overheating leaking antifreeze not from hoses and blowing white smoke from tailpipe?
I hope you are sitting down. I have some bad news. You may have cracked a piston and/or head. At least you have blown a head gasket. Time to call in the pros.
Nov 23, 2010 | 1999 Oldsmobile Alero
I got a 1987 ford ranger and its blowing white smoke and buring really rich
ITS A 2.9 LE HEAD GASKET CHECK FOR OIL IN ANTIFREEZE OR ANTIFREEZE IN OIL IT WILL LOK KIND OF FOMEY AND WHITE IN OIL
Oct 19, 2010 | 1987 Ford Ranger
It won't move and is blowing white and black smoke
White smoke (sweet smelling, too) means antifreeze is leaking into the combustion chamber, blowing out the tail end of your truck. the boiling water in your reservoir means the pressure from the combustion chamber is pushing air into your cooling system which will eventually surface in your reservoircontainer
black smoke: it can be unburned fuel damaged turbo charger etc. light amount of smoke can be normal large amounts = problem.
Aug 30, 2010 | 2007 Ford F-350 Super Duty XLT
2000 grand am blowing white smoke from tailpipes
Check your coolant!!! White smoke is a sign of antifreeze getting in the combustion chamber. Very bad if it is. Don't drive it, get it checked.
(Pressure test the coolant system is the best way)
Apr 26, 2010 | 2000 Pontiac Grand Am GT
1986 Honda Civic overheating and blowing white smoke out tail pipe when I start it up
Not good news. Sounds like a blow head gasket.
Are you losing coolant?
Oct 10, 2009 | 1986 Honda Civic
Norscot Group 1/50 Kenworth W 900 W/Lowboy Logo
714 people viewed this question
Top Norscot Group Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Norscot Group Toy Expert? Answer questions, earn points and help others
