Question about HP Computers & Internet
My Monitor gos black i can turn it on and off but it go's black fast
  • 505 Answers
Quite possibly bad capacitors.
check my tutorial, they can cause lots of problems, typically backlight drop out on monitors
ive seen bad caps in many hp lcd monitors
http://www.fixya.com/support/r5000889-repairing_tv_just_clicks_over_over
Posted on Jun 06, 2010
Computer screen keeps going black,,turn the monitor off and on,,screen come up for a bit,,the d sub appairs then gos black again
Hello there
You dont say which machine you have but a common problem is they are set for the WRONG input,
Have you checked using the 'onscreen' menu,of the monitor that you are looking at the right INPUT ???? D-sub is the 15 pin video cable input from your computer to the monitor. .It will go dark if you are not supplying a signal on that input.
Sep 24, 2014 | Computers & Internet
..Computer screne is black,,d sub comes up and
Huh? D-Sub is a connector? If you plug an external monitor into it the laptop is probably designed to shut of the internal screen. If this is not what you mean please get someone who can write a functional English sentence to clarify your meaning.
Sep 21, 2014 | Computers & Internet
Screens shows but then gos black
Confirm that all the input cables at the back are securely plugged at the rear of the screen and PC/output source and that the image source is switched on and displaying an image. This can be done by switching your PC on and waiting five mins. Then check that the power for the screen is on. If this does not work, then let me know
Jan 31, 2014 | ASUS LCD Monitor
Monitor gos black turn off then back on video stays on 15 sec then off again
Hello
It could be a bad monitor or videocard ,the only way to test this is by connecting another monitor to that PC or your monitor to another PC.
Good Luck
Feb 13, 2012 | HP Computers & Internet
I have a westinghouse monitor hd-grade 19' flat screen sometimes it gos on and it gos off i have to unplug it and plug back for it to go on and i need help .
This is usually a sign of monitor death, and it may need replacing or repairs (if you are willing). Fire you want to make sure it is the monitor and not the computer, try plugging a different monitor into the same computer, and alternately a different computer into the same monitor to isolate the problem. (A laptop can often be connected if you do not have another computer available). Unfortunately monitors aren't a product easily repairable by users. I hope this helps.
Mar 15, 2011 | Westinghouse 19" Widescreen Flat Panel LCD...
F1905e Monitor: When I turn on the monitor it goes straight into s...
The screen turn black may not mean it gos into sleep mode, it may mean it goes into shutdown mode because it may be sensing problem in the circuits.
Try it on another PC first, if it still does not work then read below.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | HP f1905e Monitor
I powered the monitor off 1 evening after watching movies I was useing the monitor as a second monitor on computer doing multi tasks, but now when i turn it on i just get a black screen it lights up at...
Your computer may not be seeing your second monitor. Go to your display settings and see if you computer is seeing monitor 2.
A fast way to check is to plug this monitor in as your primary on the computer to see if it works.
Mar 09, 2010 | Sceptre S1902D 19" LCD Monitor
The picture gos on for about 3 seconds but then the screen gos black but the monitor is still on
You could have a faulty inverter board.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site : -
www.lcdparts.net
Oct 10, 2009 | Dell E176FP 17" LCD Monitor
FPD2275W LCD Monitor power on blinks the display words- gos black
I don't think you will be able to match that IC without an ID number
Jan 20, 2009 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
