Question about Whirlpool WED9400S Electric Dryer
I have a error code of F-25, Inlet Thermistor Shorted.
I have a error code of F-25, It means i have a Inlet Thermistor Shorted. Is this a easy repair?
2 Suggested Answers
  • 12962 Answers
SOURCE: Inlet Thermistor Open F-24 flashes if the inlet thermistor is open. How do I close it? This is a whirlpool cabrio electric dryer.
Replace the thermistor to restore normal operation. It opens when appliance gets to certain temperature and then closes again to restore heat. That sucker will never work until you get a good thermistor in there.
You can always jump it and get heat but there is no safety valve in case unit overheats - could have a fire. Your call, your life.
Posted on Feb 14, 2016
What does code f24 mean on whirlpool cabrio dryer
Inlet Thermistor Open F-24 flashes if the inlet thermistor is open. This fault code will ONLY appear when in the diagnostic test mode. See TEST #4a.
http://dryernotheating.net/whirlpool-cabrio-dryer-error-codes/#F-24
Feb 14, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Error code Te2 appears, how to clear
Error te2 means that the thermistor (part the senses temperature) has a problem. Here is an excellent troubleshooting guide ApplianceJunk com LG Dryer Error Code tE2 thermistor shorted
Nov 10, 2015 | Dryers
Had error codes F-30 and F-25. Replaced the Inlet Thermistor and cleaned out the lint and the vent. How do I clear out the error codes after the repair?
two ways:
one remove power for five minutes then reconnect
or
hold stop button in longer than 30 seconds till display flashes then let go
Nov 07, 2015 | Whirlpool WED9600T / WED9600TA / WED9600TW...
Code fe on lg what does this mean
This fe error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Mar 01, 2014 | LG WM-2077C Front Load Washer
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
F25 error code
Having an error code on your appliance can be an inconvenience and I know how important it is to have a good working dryer.
The "F25" indicates the INLET THERMISTOR is shorted or the INLET THERMISTOR circuit is shorted. If you replaced the inlet thermistor and control board then it may have bad inlet thermistor circuit. You should disconnect the thermistor circuit connections at the thermistor and control board and test the thermistor circuit for continuity. Check the circuit to see it happens to be open or shorted with an ohm meter.
The inlet thermistor is located on the side of the heating element housing is a thermistor and high limit combination. The part number is 8557403. The inlet thermistor portion of the thermistor/high limit will have two solid red wires connected to it. It could have faulty new thermistor or it could have an open or shorted thermistor circuit or a faulty control board. The thermistor can be checked with and ohm meter. Disconnect the two red wires and place the ohm meter leads across the two terminals. At room temperature it should measure approximately 50k ohms of resistance. If it measures 50 k, then it should be reconnected and then the sensor circuit disconnected from the control board and retested at the harness wires to see if you get the same measurement reading. If it does measure the same, and it continues to display F25, it could have a faulty control board.
What is your model number?
Oct 16, 2012 | Kenmore Dryers
E70 error code on electrolux dryers inspire, it is working but dries the clothes to damp then this code comes up
Hi Nora King - Error code E70, typically means that there is a communication error with the outlet/inlet control thermistor that has an open or short circuit. You will need a certified professional to check the resistance of outlet/inlet control thermistor and check wiring for either short or open circuit.
Sep 17, 2012 | Electrolux Dryers
How do i clear the code " ts" after replacing thermister Thank you
The error "tS" actually means the thermistor is shorted. It flashes when the thermistor is indeed shorted, the thermistor wires are shorted, or the timer/control is faulty. There's no necessity to reset the machine. The problem here is not the thermistor but a shorted wire or a faulty timer/control. One simple way to find out is by disconnecting the thermistor and insulating the wire terminals then starting the dryer. If the error code does not vanish, then it is proven with moral certainty that there is a wire short circuit or a timer/control problem. Check and make sure that there's no such wire short circuit or no part of which is touching the dryer cabinet then if the error is still there, disconnect the wire harness from the the timer control. The timer/control is indeed faulty if the error code persists even after the wire harness is disconnected therefrom.
You have a faulty thermistor if the error code vanishes after the thermistor is disconnected. Normal thermistor resistance is around 10000 ohms at room temperature.
Aug 12, 2011 | Amana NED7200TW Electric Dryer
We have an he3 dryer, it keeps stopping mid cycle and the display reads E1
Hi
E1 error means its a Thermistor Failure. The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Kenmore Dryers
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Whirlpool WED9400S Electric Dryer Logo
304 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
