Question about Garden
Have weedeater xt112 need to replace trimmer PIVOTRIM. How ?
PIVOTRIM is the trimmer that has the lines which do not break easily - u see it on TV comercials. Problem is we need to use it to replace the existing piece on the weedeater xt112. 1st time and I am struggling.
  • 240 Answers
SOURCE: how do iremove trimmer head weedeater fl20
It depends on your model. You can visit the PIVOTRIM website and they show how to install their head on most units which includes how to take your old one off. Their website is http://www.pivotrim.com
Otherwise you need to look at your operators manual or call the manufacturer.
Posted on Jun 14, 2009
  • 1114 Answers
SOURCE: line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Posted on Jun 21, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
  • 279 Answers
SOURCE: Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Posted on Jul 14, 2009
  • 130 Answers
SOURCE: WeedEater Featherlite String Trimmer fuel leak.
give it a week to see if the fuel hose swell and stop leak sometimes i have the same problem.
and ill wait for a week and it quits leaking.try that
Posted on Jul 30, 2009
How to remove the pivotrim head from a grass trimmer
There are usually flats above the head to use a special flat wrench to hold it with.
Or take the engine off and hold the shaft very carefully not to scar it
Jun 04, 2014 | Rino Tuff Pivotrim String Trimmer Head for...
Weedeater
According to Pivotrim, it will fit your trimmer, BUT...
I can see your dilemma here.
Here is a link to the installation tips page for your type of trimmer: http://www.pivotrimhelp.com/Installation/Default.aspx
It is recommended for your model to use "Installation Method 3", here is the instructional video:
Now, It does look like the threaded, exposed end is a bit short. From personal experience with this model of trimmer, I found that the entire shaft would slip out overtime form the motor housing. With an allan key, you can loosen the joint where the shaft meets the motor housing near the throttle control. When loosened ensure that the shaft is as far up as it can go, then tighten again.
Hope this helps.
Jul 08, 2013 | Garden
I have a new Pope Renegade 26cc Line Trimmer. Started it up but the cutting line bump feed would not operate. Removed the spool from the spring head and the line was tangled. I removed the tangled line...
Hi John, I have exactly the same problem. I can't go further than about 5 feet before I need new line. I can't help, but I thought you might like to know you are not the only one having problems with this trimmer!!
Sep 09, 2011 | Toro Garden
How do I remove line head to so as to fit a pivotrim head on a 31cc 17" craftsman weedwacker
The best solution is to get the owners manual so you have complete information. Go to www.searspartsdirect.com and have your model number ready.
Jul 29, 2011 | Craftsman 25cc Gas Line Trimmer
How do I remove the spoolhead so as to afix the pivotrim head
I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
Enjoy! :-D
Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
I need to replace fuel line in Weedeater trimmer. How can I do it ?
Enter Weed Eater fuel lines in the search field for numerous results and if not, repost here.
Aug 07, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Jun 21, 2009 | Garden
How do iremove trimmer head weedeater fl20
Jun 14, 2009 | Garden
Garden Logo
151 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
