Question about Samsung Televison & Video
Not available in current mode flashes on screen. i,ve had the tv for 5 years and have not changed any connections. HP-S5053
  • krs86dls Jun 06, 2010
    when i go to the menu screen. i jumps around all on its own.
I have found a temporary solution to this problem. If you hold in the menu buttom on the tv with a strong tape, it will eliminate the message you are getting. This is just a temporary fix though!
Posted on Aug 03, 2010
  • 505 Answers
The video output resolution probably changed on your cable box for some reason. try going to an hd or non hd channel to get a picture, then you can get to the menu and video output settings to set it to 1080i and 480p
samsungs hate 480i and thats probably where it reset to
let me know if this doesn't solve the issue
Posted on Jun 06, 2010
  • thielectronick
    thielectronick Jun 06, 2010
    the menu is generated on the main or digital main board. this is an indication that something is wrong inside the tv... either with the main board, or something following that video signal on the path to the screen. could be a bad main board, lvds cable, or logic (plasma) or tcon (lcd) board
    i would look for bad capacitors on the power supply.. many of these samsung tvs had bad caps and they cause a wide variety of symptoms
    check my tutorial for more info
    http://www.fixya.com/support/r5000889-re...
HPS-5053 50" samsung plasma. never
The picture on this TV is controlled by a few things the most commond fail part would be one of your sustain boards. Second I would check the buffer boards. You can get parts at www.interliquidparts.com
Jun 03, 2011 | Samsung HP-S5053 Television
Samsung s5053, will not turn on. clicking noise inside, screen comes on and goes off. No picture. checked voltage on pin 10 get 5 volts connector cn804-1. research on internet seems to point at main...
Ken, did you ever find out what was wrong with your set and have it repaired?
I have the same "clicking" problem when first turn on the TV. First, it took about 30 secs clicking (came from the relay) then came on ok. The wait time gradually increased up to a few minutes before it comes on. Then, the power button was flashing blue light when the TV is off, but then came on ok after 3 - 5 minutes. Now it finally has no power at all.
I checked the stand by voltage at pin 10 of the CN804-1 connector and get nothing but a going spike voltage up and down on the multimeter. I noticed that one blue ceramic disc capacitor (the disc type, not the can type) was cracked and some black burned spots around it. May be it is the problem?
Mar 27, 2011 | Samsung HP-S5053 Television
How much will it cost for a cracked screen
I have a customer with a Samsung HP-S5053 in which the power supply has blown, and may have caused system wide component failures.
Rather than potentially spending a great deal of money trying to get his TV back to life, I'm certain he would be interested in either...
A: buying your TV for the good electronics
or
B: selling you his TV with a good screen.
Please let me know if you're interested in this type of deal.
You may contact me via email at sales@boiselcd.com. My name is Chris.
Oct 18, 2009 | Samsung HP-S5053 Television
Hp-s5053 samsung plasma with snow on hd content
It appears that the Main bd is bad. Try using Component cables instead of the HDMI cables and see if there is a change. If there is a change to normal picture then try another HDMI cable. If the problem returns then replace the Main bd. There three Main bds for this basic model number. You will need the version# found on the right side of the set to order the correct bd.
Jul 16, 2009 | Samsung HP-S5053 Television
Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Samsung HP-S5053 Television
50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Dec 01, 2008 | Samsung HP-S5053 Television
Samsung Plasma TV Model:HP-S5053
I had the same issues and the tech came out and replaced the main board... one way to tedt if it is the PDP is in the service menu.. run the plasam ttests and verify you don't see any dots. After replacement the tech checked all voltages and all is well.
Jul 25, 2008 | Samsung HP-S5053 Television
Samsung HP S5053 Static / Grainy Image
Try to adjust the Vscan or/and Vs down about 5-10V on the Power Supply board. If you got extended warranty, just let the warranty depot shop help you to do it.
For the "humming" noise, may need to replace the Power Supply board to fix it.
Dec 30, 2007 | Samsung HP-S5053 Television
Plasma TV picture problem
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
May 11, 2007 | Samsung HP-S5053 Television
Hp-s5053
you most have a bad conection problem, but thats a job to a tech ,dont do it your self or try to , this is a very delicate tv..good luck
Aug 06, 2006 | Samsung HP-S5053 Television
Televison & Video Logo
579 people viewed this question
Jerry Greenberg
Jerry Greenberg
