Question about Kenmore 94812 Top Load Stacked Washer / Dryer
Kenmore 417.90812990 dryer element is broken and needs replacing
I am really mechanically adapt and this one has me a little stumped I believe that I have to remove the top, front, the belt from motor and then pullup on the drum to access the element ?
  • beavo Nov 13, 2008
    Hey there, were you able to change the element in your Washer/dryer? The element on mine is shot. Just seeing how hard it is to access this element.
    cheers
    President:
  • 878 Answers
That is correct, it can be a beast sometimes. Always better to have 2 people to make it easier.
Posted on Apr 17, 2008
Kenmore electric dryer #11066512694 no heat & keeps running
Heat circuit also runs through timer and motor
Oct 26, 2017 | Kenmore Dryers
I have a kenmore 70 series dryer that overheats in evrery cycle even in the air dry cycle. Another problem is that when the cycle is done the tumbler cuts off but the timer keeps running keeping the...
Sounds like you may have two problems but the main problem might be that the element may be broken and one side is grounded, The switch on the motor may also be stuck in the on position as well.
Feb 26, 2011 | Kenmore 62802 Electric Dryer
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
Kenmore dryer (#11066832500) will not heat up. I've tried everything I know. Heating element recently replaced and still in perfect condition. I replaced the thermal fuse, both thermostats and continually...
You should trace the power from the plug to the heater to find the place where it is lost. This involves 240 volts and should be done by someone trained. It could be the timer and it could also be the power coming to the dryer. A bad circuit can show like there is power but it is not really there. (Ghost voltage) can catch the best of us sometimes.
Eric
Jun 29, 2010 | Kenmore 62602 Electric Dryer
My Kenmore series 70 electric dryer isn't heating. Replace element, thermostats, ?
a heating element would be a likely cause however before you replace the element you should check to make sure that it is bad by using an ohm meter to check the element for continuity. if you take the element out of the machine you can usually visualy inspect it and see the broken wire.
May 29, 2010 | Kenmore 67632 Electric Dryer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryer won't heat up, still tumbles but no heat. Kenmore gas dryer model #110 72612100
Each gas dryer has an electric element that heats up to ignight the gas in a small combustion chamber. for safety reasons the gas will not come on if the element is malfunctioning. After unplugging the electricity from the dryer you can get in and unplug the little element. if you can see that it is broken just replace it. if it doesn't look broken it most likely is broken but not percieved by a visual inspection. put an ohm meter on the terminals to the element and if it reads infinity the element is bad. replace the element and she should fire right up. literally.
Presto.
If the element is not the problem then it may be a wiring issue. if it looks like there has been a small lint fire in the dryer you probably have bigger issues than no heat.
Aug 20, 2009 | Dryers
Kenmore elite electric dryer want heat
chances are the element is broken. generally the element will eventually break at a weak point. if you are a "fix it yourself" type you can repair the element with a little efort. (be glad to tell you how if t you choose this as apposed buying a new one.
good luck.......jay
Mar 20, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Heating Element
There are levels of heat according to cycle and some driers do not use all the coils during low heat cycles. They rarely need replace unless visably broken. There could be a loose connection.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
173 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
