Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Track pad wont click
Cant get the glass track pad or keyboard to work.
  • Anonymous Helper
    Anonymous Helper Jun 06, 2010
    the pad is probibly broken in the inside there isn't much you can do that happened to me once i got it repaired for a pretty expensive price... goodluck though
  • 115 Answers
It is stuffed up in the inside there isn't much you can do so you'll have to get it repaired
Posted on Jun 06, 2010
Icraig 9 inch slimbook, keyboard and track pad will not work even after reset. I'm using the keyboard and track pad that are attached, no blue tooth or anything.
could be due to the driver settings if the mouse attached is a usb mouse ...
update the drivers, if that does not work ..then call in for expert help - 1-877-805-1027
Jul 09, 2015 | Computers & Internet
Why is my spacebar scrolling at times?
Hi Norman,
The keyboard acts as a text tool when you've clicked in a text box and as a scroll button when you click outside a text box on a web page. Since you say you have a laptop, I'm guessing that you click the text box to type, start typing, and while you're typing, your palm touches the mouse track pad just enough to register as a click while the mouse cursor is elsewhere on the page. I'm not sure if there's a setting to make the space bar stop scrolling altogether but there are settings to make the track pad less sensitive if your track pad manufacturer supports it. For WIndows 7, go to Control Panel>Hardware and Sound and click Mouse under Devices and Printers. As mine is a Synaptics device, this window gives me an extra tab with extra settings. It may be worth checking out yours to see if you can turn down the sensitivity. Some laptops also have a handy key combination to turn the track pad on and off. Mines Function F7, but it's probably manufacturer specific. Check your laptop documentation to see if this might be an option.
May 08, 2014 | ASUS Computers & Internet
Track pad will not click
Hi There,
I hate to say it, but you might have one the MacBooks whose battery has swelled, and interferes with using the click function of the keyboard.
If that is the case, you can take your laptop to an Apple Store and quietly, but sternly, raise hell with them so that they will replace your battery free of charge.
Hope this helps & good luck!
Apr 05, 2014 | Apple MacBook Pro Notebook
The touchpad is locked
On some models there is a button at the top of the touchpad in the middle that toggles the touchpad on or off.
On other models you simply tap twice in the upper left hand portion of the touchpad to toggle it on or off.
And then there are some models that you use keystrokes to toggle the touchpad. Normally you would Press and Hold the ALT or FN function key near the bottom left portion of the keyboard then hit the key that toggles the touchpad. The key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touchpad.
Below is what I found in your user manual on the touchpad. It looks like your touchpad is controlled by software and there is no button or keystrokes that control the toggling.
Customizing the Touch Pad and Track Stick You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel, click Printers and Other Hardware, and then click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
Below is a link to your manual
http://www.support.dell.com/support/edocs/systems/wsM70/en/ug/keyboard.htm#wp1052329
May 09, 2012 | Dell Precision M70 Notebook
CANT GET MY MAGNFING GLASS WONT CHANGE BACK TO THE ARROW
Go into your Control Panel. Click on Mouse. Click on Pointers tab. Click USE DEFAULT or pick from the list and then click apply OR OK.
Jan 23, 2012 | Logitech Cordless Mouse
My mouse pad on my lap top isnt working, it moves around but when i click it wont select or click or i dunno what to call it lol, **** the right click works, just not the left.
Sounds like the track pad button is broken. Unfortunately that would mean it needs physically replaced. I might suggest using a USB mouse instead.
Mar 23, 2011 | Computers & Internet
How do i unlock the hardware of keyboard? its lock, cant press it anything. im typing on screen laptop. its hp pavilion entertainment pc.
there is a button just above the track-pad (mouse controller) that normally only dissables the mouse but it might work for this too.
Mar 07, 2011 | HP Computers & Internet
Both shift key wont work on my laptop
Remove the top pads of the keyboard and use a good cleaning brush with a vacuum cleaner to remove off all the dirt from within specially of dust accumulating . If there is no response check the link from the keypad to the motherboard, remove and reset the connection.
If not the fault can be failure in the contact pads below the keys.
Open control panel and click on keyboards, change the settings for user with more sensitivity and save. If this wont work the keyboard panel must be checked again.
Nov 25, 2010 | Computers & Internet
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
Click the Touch Pad tab to adjust touch pad and track stick settings.
May 07, 2010 | Dell Latitude D610 Notebook
Keyboard
From the Dell D620 Users Manual:
  1. Open the Control Panel and click Mouse.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
50 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
