Question about Dishwashers
My lg dishwasher LD-14AW2 is not starting. It turns on and displays the time but when I click on anything it double bings and nothing happens. I have cleaned out the filters and my husband has removed the drain hose from the s band and it was all clean. the display looks normal...no error code. Do you have any idea what the problem could be?
  • 523 Answers
Tunr power off 20 min then back on see if this helps
Posted on Jun 06, 2010
I had the same problem, and found the issue by chance.
There is a switch in the handle that checks if the door is closed, mine got wet somehow and shorted the switch, therefore it kept sending an open door signal and it would not start. I removed the switch and dried it and it then worked.
Posted on Jul 28, 2015
Dishwasher wont start
Most likley problem is the door is not closing properly or the door latch switch is faulty. This means the dishwasher controller is not getting the right signal before commencing the wash cycle.
Need to check the closure of the latch. If this is ok then replace the door switch.
View the door panel diagram, schematics and parts in this site
http://spares.bigwarehouse.com.au/index.php?cPath=24759_25855_26296&sort=2a&page=1
Apr 23, 2014 | LG Dishwashers
I have a LG LD-14AW2 dish washer. it starts and then displays "HE". Is it the heater unit?
Hi glen bundese,
Yes it is the heater unit...
HE means Heating Error - The Element needs to be replaced - Or the Thermistor on it, though if the thermistor was faulty it would give a TE error.
Both parts come as a unit (Usually). I would refer you to a qualified L.G technician in your area
- Replace the element unit, and things would be OK.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful, please rate it.
Jun 11, 2011 | LG Dishwashers
I hav a lg Dishwasher model # LD-14AW2 the problem
broken door cord. remove side panels and relace. this is a cheap and easy fit. make sure you replace both sides at the same time, you will most likely find it is only one side broken at this stage, but the cords do not last very long.<!-- from fixya rte -->
Jul 07, 2010 | Dishwashers
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher model LD-14AW2 comes up with E 1 fault all the time
I took the side panel off and found the start capacitor for the pump motor burnt out.I purchased a new 5 uf capacitor for $9 and installed it.
Regards Neville OBrien
Nov 28, 2008 | Dishwashers
LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LG Dishwasher
Had a similiar problem I tried reducing water pressure from water inlet (external to dishwasher) and this worked to a certain degree, although may result in being unable to fill, if you turn down too far. Water silencer (try plumbing stores) was fitted between mains and dishwasher and this fixed the problem.<!-- from fixya rte -->
May 16, 2008 | Dishwashers
LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
312 people viewed this question
Top Dishwashers Experts
