Question about Sharp R-1481B Microwave Oven
The work light and the night light
The night and work lights do not work. We replaced the bulbs, we would like to know where else to check. Schematics with detail would be nice. HELP I appreciate it.
  • Sharp Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Kenmore microwave nights light don't work.
    That's a problem on the circuit board which can be repaired simply and inexpensively.
    A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
    Nov 30, 2012 | Kenmore 62622 Microwave Oven
    I have a GE Spacemaker model JVM140H 002. The night lights work, but the main lights do not work, I can hear the relay clicking and the night lights go out.
    At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
    Dec 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Whirlpool MH7140XFQ-1 light does not switch from regular to night
    If there are 2 bulbs try swapping them around. If the night light works then you just need a bulb. Take the bad one with you and match it up at a parts store. Some actually have a dimmer circuit programmed in the board and that will not be a easy fix. Do you hear a click when you try to activate the night mode? If you cannot find a bulb or do not want to replace or repair the unit just disclose the non working light. I was in real estate for a couple years and a burned out bulb will not be a deal breaker as long as they are told up front.
    Eric
    Jun 08, 2009 | Whirlpool MH7140XF Microwave Oven
    Surface and night light bulbs
    If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
    May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
    Microwave PLMVZ169 GCB night light push button does not work. Replace the light bulb. Push button still does not work. The work light does when I push the night light it stays on. Just wondering how to...
    Q - While trying to change the light bulb on the oven, the bulb broke. When it did, it threw the circuit breaker and the whole oven went out. After resetting the breaker, everything on the oven works except there is no power to either light socket. Any ideas or suggestions on what to replace?
    A - You tried to change the light bulbs with the power still on.....tsk tsk!!
    Hate to say this....but probably blew out part of the circuit on the smart board ( the brains behind the key panel you touch ) when the short blew. The light relay on the smart board may have been damaged but 9 out of 10 times when I check them, the board itself is damaged.
    check out this problem.
    please do rate the solution.thank you for using fixya.keep updated.thanks,
    May 03, 2009 | Microwave Ovens
    Work light and night light do not work on Sharp Carosel R-1481
    > Work light and night light do not work on Sharp...
    Thanks for giving us the model number.
    We regularly repair these R1481 control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    Feel free to contact me directly (and please remind me of your full model number) for more information & help.
    William E. Miller
    prototech@usa.net
    Nov 22, 2008 | Sharp R-510HW Microwave Oven
    GE Spacemaker Model No. JVM1650AB 003
    Hello Diana,
    Here is a link to the GE User manual for your microwave oven.. Once you download it.. You will find a section on light bulb replacement that details how to install and which particular bulbs to use..Hope this helps you..
    http://genet.geappliances.com/DocSearch/pdf/49400821.PDF
    Good Luck !
    Sep 14, 2008 | Microwave Ovens
    Lighting Problem
    We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
    Mar 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Burning smell and light switch does not work
    The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
    Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
    Sharp R-1481B Microwave Oven Logo
    102 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
