Question about Canon PIXMA iP4000 InkJet Photo Printer
Canon ip4000 remove print head
Canon ip4000
how is the the print head removed?
    Scholar:
  • 128 Answers
Hi! You may access tha manual by clicking here. Please use the set up instruction manual (2nd m,anual from the top). Thanks for visiting FixYa.com!
Posted on Jun 06, 2010
Tip
How to unclog a clogged print head on the Canon...
Using a cotton swap dip into some plain water and then drop a few drops of water onto the outlet of the ink cartridge [you will have to remove the ink cartridge and turn it upside down].
Also while the ink cartridge is still removed, drop a few drops of water onto the inlet orifice into which the ink goes. The orifice of the ink cartridge sits right on top of the inlet to the print head when the ink cartridge is fully installed.
After putting the water drops onto the ink cartridge and onto the inlet orifice of the print head, I did the 'clean' procedure as listed in the "Canon PIXMA iP4000 Properties" of the program on my PC. Then I did the deep clean procedure. After that I printed the print pattern and found that this technique worked quite well -- since before I had tried isopropyl alcohol which didn't work to unclogged these print heads.
When I had the blue print head get clogged [on my Canon iP4000 Pixma printer] and I tried this method. It worked immediately.
I hope it works for you too.
God be with you!
engineer550.
on Jun 16, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My printer is Canon ip4000 and it used to be okay until lately. There will be 5 flashes of orange light and then green light. I checked on the internet and it says that the ink head has problem. Each time...
Remove the cartridge and clean the head as well as the printer head with cotton&alcohol to remove dirt. Insert it again and have a long press on the resume button... Have a test print...
Sep 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Only black ink won't print. Even with new black 3e and new black 6 cartridges.
The black ink is a pigment based ink, that is it consists of particles suspended in a solution. The colors are dye based and have no particles. This being the case when the black ink dries and clogs the print head the particles are left behind. I would suggest removing the print head and letting it sit on a paper towel moistened with warm distilled water. Do this on a surface that is both waterproof and disposable, i.e. a plastic disposable plate, since the hope is that ink will flow out. Let this sit for about 20 mins, reinstall print head, making sure the electrical contacts and clean and dry, then the cartridges and try cleaning cycles again. If still no luck replacement print heads are available at the address below.
http://www.precisionroller.com/print-heads-for-canon-pixma-ip4000/products.html
Jun 11, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Doesn't print black text despite full cartridge
It may be problem in print head or purge unit, bzt first did you try with print head cleaning under printer properties/preferences?Try few times, if not, remove ink crg., remove print head, take lint free clotch and moisture it with destilled water and put the print head on it few minits, then dry it with anoter lint free cloth.Put it back in and repeat the head cleaning and nozzle check.
If not helpfull replace print head and purge unit with absoerber
Mar 06, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Yesterday I got a message that the print head needed to be reinstalled. This morning when I turned on the computer, I found I couldn't turn on my Canon Pixma iP4000 printer. I checked the power cord, and...
The print head is what is holding your ink cartidges and can be removed. Do as it says and remove it and then reinstall it. If that fails to work, you can try going somewhere like Staples to pick up a new print head, if they have any in stock.
Thats a really decent printer by the way; a great deal when they came out and a solid performer.
Aug 05, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
When printing pictures, there are faint white vertical lines on
Cleaning usually doesn't help that printhead much. A new one QY6-0049-000 is around $40.00. You remove by lifting the gray handle on the left after removing all the inks.
Jun 30, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma ip4000
I think there is ink contamination on the bottom of the print head. Remove all cartridges and then remove the print head. Wash the bottom of the printhead with hot water. After that dry with a cloth. Make sure its fully dry. (Toiletpaper does a good job of drying the printhead). Make sure no ink is leaking out of the cartridges. Replace everything and then run a deep cleaning test.
Good Luck
Hope this helps
Thanks for reading!
Apr 30, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Poor color
Mr.Musculo is very helpfull in cleaning head prints.
Jan 11, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
374 people viewed this question
old marine
old marine
