Car over heats change thermostat and water pump
    Problem Solver:
  • 5 Answers
Is this a older car if so did you flush the rad or ckeck the heater core, or maybe it could be sofe hoses ,if the hoes becomes soft then it will not flow properly and over heat. good luck
Posted on Apr 10, 2008
2001 DEVILLE HAS NO LEAKS BUT RUNS HOT. WHAT IS THE PROBLEM,WATER PUMP OR THERMOSTAT.
I would change both first get a fail proof thermostat that way it would never over heat put it in and see if you got heat. if you got heat thermostat is good and water pump check your fans and make sure coolent is full make sure oil looks good you don't want to over heat that car or you will burn hea
Jul 11, 2014 | 2001 Cadillac DeVille
1995 sentra heat problem.i done the head and replaced the water pump and redaitor cap and just had the head skimmed when i go on a hill its heating
Did you change the thermostat. It might be stuck halfway open. When you start to go up a hill, the engine heats up more, the thermostat needs to open more, to let more coolant by to the radiator.
Mar 31, 2014 | 1995 Nissan Sentra
Thermostat
if you have changed the thermostat i would replace the water pump. i have fixed a couple of trucks that didnt have any heat and it was the water pump not working like it should
Jan 29, 2013 | 2005 Nissan Pathfinder LE
02 isuzu overheated
check your coolant level. Check to make sure your cooling fan is running, Thermostat could be an issue also. Also check water pump. To check thermostat feel top radiator hose when vehicle heats up if it gets hot your thermostat is probably working if it does not then ur thermostat is probably stuck closed and needs to be changed. If your water pump is leaking out the weep hole (small hole at neck of water pump) then you will need to change the pump because it is going or has gone out.
Dec 24, 2011 | 2002 Isuzu Rodeo
Have an 2003 Olds Alero 2.2L, overheating. Removed thermostat housing/feed pipe to check thermostat to find no thermostat present, however the heat has working, although it has took 5 or 6 minutes to warm...
I can't give you any specifics on how to change your water pump, but I can answer your questions about the thermostat. Yes, the heat will work withou a thermostat. And yes, a car will overheat without one, especially in the summer months. The purpose of a thermostat is to allow cooler water to flow into your block, but also to allow the water adequate time to be cooled in the radiator. Without the thermostat, water is continuously cycling through your coolant system, getting hotter and hotter. Often I see people with malfunctioning thermostats jsut remove them, sometimes on the side of the road, just to get where they're going.
May 02, 2011 | 2003 Oldsmobile Alero
My cars interior is not being heated.
If the motor over heats it may be the water pump. A motor will not run very far with a bad water pump or stuck thermostat. Most of the time a water pump won't quit pumping water they leak. If the motor won't get hot enough it is the thermostat.
Jan 06, 2010 | 2002 Dodge Intrepid
Car is over heating. Alero 2001
If you changed the hoses and thermostat and the car is still overheating, then the next thing to look at is the water pump. See if the water pump is leaking water from a vent hole. If it is, then the water pump is defective and will need to be replaced. Sure hope this helped.
Jul 20, 2009 | 2001 Oldsmobile Alero
Cant figure out how to change the thermostat on my 2003 Olds Alero.
  1. (This is for a 2.2L engine) If equipped with an automatic transmission, remove the exhaust manifold.
  2. Drain the cooling system.
  3. Remove the thermostat housing to water pump feed pipe bolts.
  4. Remove the thermostat housing to water pump feed pipe.
  5. Remove the thermostat.
Jun 24, 2009 | 2003 Oldsmobile Alero
2002 pontiac grand prix over heating
Are your electric fans engaging or turning on?
Dec 26, 2008 | 2002 Pontiac Grand Prix
2004 Mitsubishi Eclipse-no heat?
check thermostat and water pump.the water pump could be working good enough to ke the engine cool but dosnt have the pressure to push it thru. i ran in to this prob be for no heat and the engine didnt over heat. the antifreeze ate the blades off the water pump. it was crazy.
Dec 23, 2008 | 2002 Mitsubishi Eclipse
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
