Cant set the wireless lock on my linksys wireless-g wrt54g router
    Scholar:
  • 134 Answers
The following article should answer any question you may have about securing your wi-fi connection:
http://www.cas411.com/ShowArticle.aspx?ID=68
Posted on Apr 10, 2008
Cant connect to my dell inspiron 8100
I think you should check the wireless settings of your router first.
If your wireless network is secured then make sure that you have the correct wireless network key WEP / WPA .
If your router is too old then it will be better to upgrade the firmware of your Linksys router.
Jan 01, 2012 | Linksys Wireless-G WRT54G Router
Im trying to find my password for my router but i cant.
Reset Button
Note:
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
The first method involves simply pressing a button located on the back of the router. The image below (courtesy of Linksys) shows where the button is located.
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1′ in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless-G Router to secure your router and create a good wireless network security.
Through the Web Administration PagesThe second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is "192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn't, the default is no ID and "admin" as the password.
  3. At the top of the Web page, click "Administration" and then "Factory Defaults".
  4. Beside "Restore Factory Defaults", click "Yes".
  5. Now click the "Save Settings" button at the bottom of the Web page.
Your WRT54G wireless router should now be reset to the factory defaults. Ensure you follow the steps outlined in Securing Linksys WRT54G Wireless-G Router to secure your router and maintain your wireless network security.
SummaryThis post has provided two methods you can use to reset your Linksys WRT54G Wireless-G router. If you are having problems with your router, try resetting the router to the factory defaults, and then make the changes again and see if the router starts working again.
Sep 24, 2011 | Linksys Wireless-G WRT54G Router
How can i find out my pssword.
The default username and password for Linksys routers are:
Username: admin Password: password
or
Username: admin Password: admin
or
Username: <no username> Password: password
If all of this fail you'll need to reset your linksys router so that it will also reset the password to the default. To reset you linksys router you can check it out on this website: http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Note: Reseting your router means it's going to reload the factory default settings and all of the settings that you made on your router will be deleted permanently.
Apr 23, 2011 | Linksys Wireless-G WRT54G Router
How do i get a security code so others cant use my internert
type 192.168.1.1 into your browser and hit enter. This will take you to your router page.
If you have never been to this page before this is a list of defualt passwords to enter your page.
Linksys BEFW11S4, WRT54G: admin
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys Comcast routers: comcast
All other Linksys routers: [none]
Default passwords: Linksys BEFW11S4: [none]
Linksys Comcast routers: 1234
All other Linksys routers: admin
From here you can set your own wireless security mode and generate a passphrase or key to lock out intruders.
Hope this helps...Good luck
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | Linksys Wireless-G WRT54G Router
How can i lock my linksys wrt54gs router if i dont have the disk?
Down load the user manual for you model here
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G/download
then check the security settings and set the firewall setting s in the rouiter
follow the guide it is in PDF form.
You didn't supply the version number for you unit.
You will have to do a search at the site above for the correct
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
Cant setup or connect to internet through router
Different ISPs require different configurations. If you have a Linksys router, such as the WRT54G, there are 2 ways on how you can configure it, either by running the Setup CD or by doing manual configuration. This particular router has its own web utility and you can access it by typing its IP addres on your web browser, ex. http://192.168.1.1. By default, it doesn’t have any username and its password is admin.
Once you’re inside the setup page, you can configure now the router for DHCP, PPPoE or STATIC IP settings. For DSL customers using a PPPoE account, some modem needs to be configured into BRIDGE MODE first and then the router will be set to PPPoE with the correct username and password (given by ISP). If your a DHCP account, modem doesn’t require any configuration. It will work with its default setting and the router would be set to DHCP. Once done, powercycle your devices to establish internet connection.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g, need console on pc but dont have disc
Are you trying to connect the Xbox to the wireless network?
If yes then you will need to check the wireless settings of the router.
is there any computer on line using the router ?
on that computer you can open the setup page of the router. check the wireless ettings and the security settings then try to connect to the wireless network on the Xbox.
See if that works.
Click here for more information
Jun 17, 2010 | Linksys Wireless-G WRT54G Router
I cant get my xbox 360 wireless to connect to my linksys router
You will need to check the wireless settings of the router is there any computer connected to the router ? If yes then you can open the router set up page on that computer. Router set up page is the page where you can check all the wireless settings of the router.
Apr 05, 2010 | Linksys Wireless-G WRT54G Router
Our linksys wireless router just quit we cant get
May be your router might got resetted.
you will need to check the settings on the router or you will need to reconfigure the router.
It depends on the Inetnet service povider.
Click Here for more info on routers
Oct 08, 2009 | Linksys Wireless-G WRT54G Router
WRT54G
who is your internet service provider and what is the operating system of your computer. If you cant recall the password for the router then you can reset it and start from scratch. By the way the default password of your router is admin.
Jun 05, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
