Question about Roper REX4634KQ Electric Dryer
No heat Working but no heat
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Heat and air unit heat stopped working
1-Check Thermostate for setting may wrong or Th. faulty.
2-Fuse near to heating element blown, Change it.
Nov 12, 2013 | LG Electronics 23,500 BTU 230v Window Air...
My Sanyo PTAC heather stop working. ac working, fan working .
It could be the relay or the strip heat....
To figure out what is wrong you will need to check if power is getting to the strip heat or not...should have 220-240 V across the two legs going to the heat strip...when the heat should be on.
heatman101
May 25, 2011 | Sanyo STW0923H2 Air Conditioner Heat Pump
The heat sistem is not working well is working but 30% of eficency than it was working beafore.It hear like water on it ..help im frezzing
Air conditioning real definition is not giving cool but removing heat from the room. In same way for heating, it's not heating, removing cool from the room. When your indoor coil, air filter and blower wheel are full of dust, you won't get even 30% of cool or heat depend on your selection.
Simple solution for your problem is clean indoor unit completely. Check all sensor is working well. In heat mode keep temp minimum +3 degree than room temp. thanks and helpful.
Jan 30, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Hotpoint dryer not heating, dryer tumbles but no heat.
check the switch is working then go to the heating coils and check there working ok the next thing to go to is the heat censor inside above the door if this is not working you wont get any heats at all,
Jul 01, 2010 | Hotpoint Dryers
KGYS850LT / KGYS850LE / KGYS850LQ Gas Dryer: The drier is working fine just no heat?...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 18, 2010 | KitchenAid KGYS850LT Gas Dryer
Hotpoint Dryer Heat stoped working
Loook inside door an get me the model number. The heat thermistat and the high limit switch will possibly need replaced. Enter the model and part numbers in the search feature on my site below. We offer free help and assiatance also. Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Hotpoint Dryers
Heating not working
Hi first have you checked the heat control dial to make sure that is functioning,,, if it is then it will be the heater core matrix, Hope this helps
Regards
Steve
Dec 11, 2008 | 2001 Daewoo Lanos
Wirlpool dryer heating poorly
Make sure you have got it set to full heat and not half heat, you may have a faulty heat selector switch.
Dec 09, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
154 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
