Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Intermitent horizontal and vertical rolling - Mitsubishi WS-55613 55" Rear Projection HDTV
  • 505 Answers
Just when its cold?
likely the caps on the 9volt regulator on the signal board.
they're solder in, but you'd have to read the values off them as I can't remember the value
let me know if you want to dive in, i can help
Posted on Jun 06, 2010
Horizontal lines on led/tv with rolling vertically.
This sounds like a panel issue unfortunately, if its under warranty or you purchased an extended warranty great, if not your kind of SOL
Nov 26, 2017 | Vizio Televison & Video
I have 2 lg repair the same trouble vertical horizontal rolling
Vertical or frame rolling indicates adjustment of the frame hold is required or perhaps there is a synchronisation fault.
Breaking of the picture in the horizontal plane is caused by the line hold requiring adjustment though the symptom can be connected with interior or exterior signal problems or perhaps a power supply fault, especially where both the line and frame are affected together.
It is probably a task for an engineer or at least someone with access to the servicing instructions.
Feb 25, 2015 | LG Televison & Video
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
Vertical rolling of picture
psess the volume  up and down button together on the front pannel of the tv and then shut off the tv and it will stop scrolling.
Jan 05, 2009 | Akai LCT3201TD 32 in. LCD Television
Lines on tv
Hi
this not horizontal this is vertical line. this means defective vertical output IC and 1.5ohms resistor, Replace the two parts then test run, and happy viewing!
Thanks!
Dec 26, 2008 | Sharp 25L-M100 25" TV
TV Shuts Down
you may have vertical intermitance resold vertical ic or check connector to deflection yoke some time is intermiten..
Mar 23, 2008 | Mitsubishi VS-55707 TV
Tv roll
Are you sure the roll isnt Vertical? as if it is then all you need to do is adjust the VERTICAL HOLD PRESET POT which should be located on the PCB somewhere, its very unusual for TV.S to roll horizontally as then the picture just goes out of sync. and you would not see a picture at all. When you find the pot turn it ( with a small screw driver) slowly until the rolling stops, if it does not stop then you have a faulty component in the vert. sync. circuitry.
Feb 04, 2008 | Televison & Video
PROBLEMS WITH VERTICAL ROLL
That is not a vertical roll from side to side, this is a horizontal rolling. if the vertical had a roll it would be going from top to bottom. This is most likely a coupling between the horizontal sync circuit and the sync separator circuit. Good Luck
Jun 28, 2007 | Sony KP-53S65 53" Rear Projection...
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Picture has a horizontal row
this symptom is caused by a trouble in the integrated circuit of in the vertical oscillator circuit. try to look if your tv has a vertical hold control at the back or inside, if it does not have, u have a problem in the vertical oscillator circuit. by the way, its not the horizontal that u should concentrate into, its the vertical. coz this is a vertical sync problem.
Jan 12, 2007 | Konka K2001UM TV
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
