Question about Compaq Presario Notebook
Need help my notebook it said that hard drive 1-7 fail what can i do
  • 115 Answers
You can go and get a new hard dirve there are cheap ones at office works goodluck...
Posted on Jun 06, 2010
PXE-E61 : MEDIA TEST FAILURE , CHECK CABLE
Normally, your laptop should be configured to boot up from the hard drive before trying the network boot up. When the hard drive fails or is no longer available, or the boot up sequence in BIOS Setup has been changed so that the network boot is set before the hard drive, the symptom you describe fails.
I would recommend that you do the following:
1. Check BIOS Setup & make sure the boot sequence is set in the correct order (Hard Drive 0 should be before Network Boot).
2. Make sure that the hard drive is seated properly in its slot & that all connections are tight.
3. Make sure that the hard drive powers up when you turn on the laptop.
If none of this helps, then your hard drive has failed & might need to be replaced.
Mar 09, 2011 | Compaq Presario 700 470024-192 Notebook
Pxe-e61: media test failure check cable pxe-m0p:exiting broadcom pxe rom operating system not found
If none of this helps, then your hard drive has failed.
Mar 08, 2011 | Gateway MT3705 Notebook
Computer switches on but screen remains blue and unable to obtain cursor
Looks like the hard drive has "lost" the OS.
You have a few options:
  1. Reboot to safe mode (f8) and see if you can access the computer through that
  2. Do a repair of windows using the recovery partition or the Installation DVD
  3. If a recovery fails, get the data off your hard drive and reformat the hard drive and reinstall windows
  4. If this fails, the problem could be with a faulty hard drive,or issues with the graphics driver / chip
Repost if steps 1-4 do not help
Jan 03, 2011 | Acer Aspire 5735 Notebook
Failed segate drive need replacement solution
Yes the ATA-300 is compatible with notebook computers.
I use Hitachi HTS7210 80GB.
Oct 07, 2009 | Seagate (ST9402113A) 40 GB ATA-100 Hard...
Failed Replace hard disk 1 warranty id code 10008
As the error message states you need to replace the hard drive as the hard drive is most likely dead ie not working / broken.
Apr 16, 2009 | Compaq Presario M2000 Notebook
DST result fails
DST test is for Hard Drive - if this test failed, you will need to buy or contact technical support for a replacement Hard drive.
Hope this helps!
Jan 11, 2009 | Dell Latitude D600 Notebook
Hard Drive Fail
I don't know the specific error code. There is some information on wikipedia
You could try reformatting, which may or may not help, but the line at the bottom is: do you want to risk your data to a dodgy drive?
Sep 28, 2008 | HP Pavilion ze2000 Notebook
Os not found
Operating system not found indicates that the system is not seeing a bootable device. Possible causes are:
1. Hard drive not detected due to loose connection. Reseat the HDD.
2. Hard Drive is failing/Failed. Replace HDD
3. System has a floppy drive and a diskette in the drive, remove diskette, reboot
4. Hard drive not in boot sequence. Reset BIOS to defaults
Jun 22, 2008 | Acer Aspire 5050-3242 Notebook
SMART error
i think u have to try to RE-install OS
Nov 03, 2007 | HP Compaq Presario v3000z Notebook
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
