Question about Toshiba 56HM195 56" Projection HDTV
Have sound no picture lamp does not appear to be bad when looking at it yellow light blinks the shuts off tv then tries to start and can hear sound but no picture it will keep doing this till i turn the tv off
  • 505 Answers
Listen for the colorwheel noise
you'll recall hearing it "wind up" as the tv came on
many of these will go bad and then it will never fire the lamp because the colorwheel doesn't get up to speed
if you don't hear it, suspect the wheel, its hard to get since toshiba never had it as a seperate part
if you do hear it, its probably a bad lamp driver, but unlikely
let the tv go and go, it will try like 7 or 8 times and then eventually spit out an error. your user manual has the error codes, it will tell you if its the colorwheel i belive.
let me know if you need further assistance
Posted on Jun 06, 2010
Toshiba 56hm66, lamp replaced but lights still blink
Check the circuit boards to see if any have failed. They are small cylindrical objects. If the tops of any of these are bulged instead of flat then they are bad and board will have to be replaced. Hope this helps.
Jan 03, 2014 | Televison & Video
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
I have a Toshiba model 65HM167. The bulb exploded about 6 months ago so I replaced it and everything worked fine until now. Now the TV will power on and I will get sound but no picture. The yellow light...
Unfortunately lamps go bad without the visible state of being bad. I don't know who or where you bought the lamp from but I order all my lamps through dlplamps.com
The clicking sound you hear is the lamp inverter igniteing the lamp but the lamp is bad.
Nov 29, 2010 | Toshiba 65HM167 65" Projection Television
No picture on my samsung 61" dlp.
The color wheel if bad enough, will cause the lamp not to light. If the lamp is truly bad, you can't usually tell by just looking at it unless of course it is broken.
May 18, 2009 | Samsung 61" Slim-Depth DLP HDTV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
TV turned off and wont come back
looks like the color wheel its bad in the set,color wheel its not spining at its proper speed( one of the segments may be broken)
thats the vibration you are hearing.. and the set its trying to turn on..until you replace the wheel you will be able to watch tv again.
hdtvman
Jul 03, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Oct 19, 2007 | Samsung HL-R6167W 61" HDTV
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 56HM195 56" Projection HDTV Logo
215 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
