Question about Kenmore 44042 Front Load Washer
Brown Gunk When I wash my clothes, there is quite a bit of brown gunk on the glass door and in my clothes. It is also all in the rubber part of the washer. Any ideas...
Suds gunk will build up in the folds and edges of the rubber inside the door opening of the washer. When this happened to my clothes, I cleaned it thoroughly (couldn't believe what was there) and had no further problem. Now I wipe it down after each wash. I also ran a vinegar wash and put baking soda in my next several loads after cleaning. Now if if would only do a final spin!
Posted on Aug 22, 2008
  • 1,073 Answers
Sound like mildue issue, there is a product out there called Affresh that will remove the mildue can get it at lowes item number is 163338 about 7 dollars
Posted on Apr 11, 2008
1999 jimmy overheating and only blows cold air, also reserve is brown gunk
Is there water in the oil? Does it look like a chocolate shake?
Jan 14, 2013 | 1983 GMC Jimmy
Bosch Maxx 2000 leaves brown sludge on washing. Has it died?
Is the rubber seal around the drum perished or has it not been cleaned for while? The seal should be wiped out after every use, you may find it full of gunk if you run a cloth around inside the seal.
May 05, 2012 | Washing Machines
Brown gunk on clothes when cycle is done.
Main barring seal is leaking that turns drum. Replace seal
May 08, 2011 | Washing Machines
Slimy - stinky - brown residue on my clothes after wash
Check the water inlet valve/ Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are free of rust or debris. The small screens tend to get rusty due to elements in the water and can cause the type situation you describe. I will attach a photo for reference. Hope this helped and best wishes.
Sep 04, 2009 | Washing Machines
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Kenmore goo/gunk
If it's a front load washer do not put to much soap in it!This can gunk it and cause the bearings and seal to go bad!
Follow the washer directions for detergent amounts.
PS . Please give me a good rating here on
Thank You ngfam2
Aug 22, 2008 | Kenmore 44832 Front Load Washer
Whirlpool duet front loader washer/dryer
It is not the dryer causing the problem. We get the brown streaks on our white clothes before putting them in the dryer. I have ruined more white clothes over the past six months with this Duet washing machine!!! We also don't use bleach so I don't think it is the HE/Clorox combo that somebody mentioned earlier. Anybody know what exactly is causing this yet... before I throught the moldy stain causing Whirlpool duet out?
Aug 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Grimy brown residue
the leveler and universal need to be repaced these are the parts underneath the plate in bottom ..residue and corrision are coming off and getting redeposted inside also cke recirculating tube right rear sometimes gunk will accumilate there but my money is on the universal and leveler both come in a repair kit
May 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 44042 Front Load Washer Logo
152 people viewed this question
Sal De
 Brian Main
Brian Main
