Question about Friedrich QuietMaster Deluxe RS12L10 Air Conditioner
On and off knob broke need replacement - Friedrich QuietMaster Deluxe RS12L10 Air Conditioner
  • 6,927 Answers
Just go to a appliance dealer,and order one,they will most likely have it in stock.
Posted on Jun 06, 2010
Do I really need to replace the whole oven thermostat on my Viking if only the knob shaft broke off?
I would follow his recommendation. If it is not repaired correctly you will have temperature problems and it will hold the know in the right position.
Apr 29, 2014 | Viking VGSC306-4B Gas Kitchen Range
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
2003 mitsubishi outlander temperature control knob would get stuck while turning..and finally snapped off and broke
The source of the problem is not the knob it is the temp blend door binding. Putting to much stress on the knob. If you replace just the control head with the knob it will only break again. You need a dampener repair kit and to install you will have to remove the dash and heater core.this will slow you to access the door that is binding. Hope this was more help then it broke replace it.
Nov 09, 2011 | 2003 Mitsubishi Outlander
I have an older a/c model no. A494901 (?). The control knob broke off. Is it very hard to replace it with a new knob? And, where would I get a new knob? Thanks, -Fran O'Neill
Depending on your break is the stem leading from the settings selector switch still there or did it break to. If it broke as well you will need to replace both the selector switch and the knob. If not the knob can be obtained from your local Sears Repair Center.
Jul 05, 2011 | Kenmore Heating & Cooling
The volume knob from my right computer part Rev A00 broke off. Computer model Dell dimension 2400. Can I get a replacement knob and where?
Sounds like you broke the volume control knob for your speakers (Likely A215s)
Best bet, new pair of speakers as they don't sell replacement parts for the speakers themselves
Apr 24, 2010 | Dell Dimension 2400 PC Desktop
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Knob broke off my A/C with the peg inside!
Simple you either replace the knob assembly or use araldite and fix off the broken knob. It is only a temporary remedy and for a permanent solution please replace the knob assembly and get rid off this problem
Jul 14, 2009 | Heating & Cooling
Sunbeam Rocket Grill - knob broke - where can I find a replacement?
I contacted Sunbeam at (866) 588-1081. They are supposed to send a replacement timer knob in two weeks at no charge.
Mar 03, 2009 | Kitchen Appliances - Others
Timer knob
I went to rivalproducts.com and contacted them. I am waiting to hear back. Good luck! They should take care of this...!
Nov 06, 2007 | Rival RCF25 Deep Fryer
Friedrich QuietMaster Deluxe RS12L10 Air Conditioner Logo
90 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
