Question about Jazz DV-179 Digital Camera
Memory Card I just purchased a Jazz DV 179. It takes an SD memory card, but I cannot find out what size of memory crd will be compatible. Also I have a Mac and cannot download the disc. Can you help me please and thanks.  My email is giomaria@rogers.com
  • Anonymous Apr 19, 2008
    I just bought the Jazz dv-188, pretty much the same as the 179 and have a Mac also. I can't get the video to play on my Mac. Since it is USB it has to download into iPhoto instead of iMovie that wants a firewire connection. Are you able to get the video working, I can get the sound to work but not video. I have tried clicking and dragging, importing etc.
    email: kirkrobbins@cableone.net
  • 90 Answers
Please call Jazz Products @ 732-572-7050
Posted on Jun 30, 2008
Jazz dv163 keps saying card locked..........
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 05, 2011 | Jazz DV-179 Digital Camera
SD card can't be read "Card Locked" is all that
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 27, 2010 | Jazz DV-179 Digital Camera
I have recently purchased a Jazz Digital Camera and I am very disappointed because I am unable to download my photos because the camera is not compatable to download with windows Vista series.. Is ther any...
I have searched all over the place for an anwer to this without much luck.
My only suggestion would be to run it in compatibility mode for Windows xp and/or run the compatability wizard.
Click start> help and support > type in compatability wizard and it will bring up a list of options.
Click on compatability wizard and it will open.
Alternatively, find the file on your computer that won't load/run properly, right click and select "properties" then "compatability" tab and you can select what operating system to run it in.
Hope that is of some help to you.
Nov 10, 2009 | Jazz DV-179 Digital Camera
Jazz 179HD - memory card locked and battery charging
Try taking out the battery and turning it around. Making sure it's in correctly. Plug the USB cable in the back under the directional pad. Pleas, rate me!Watch close for Dragonflies
Jun 11, 2009 | Jazz DV-179 Digital Camera
Whats the max. size of card can i use in it
Any card size will wour but make sure its compatable with your camers...and stay away from HD SD cards they will not work in this model!
That should fix ya!
Dec 12, 2008 | Jazz DV-179 Digital Camera
Jazz dv-187 digital camera
You can use an SD memory card for your camera.  There available at most stores.
Is the battery indicating that it is fully charged?
Oct 27, 2008 | Jazz DV-179 Digital Camera
Jazz dv-179,cannot extract SD VIDEO
coke and pepsi are the same thing.
Jul 05, 2008 | Jazz DV-179 Digital Camera
Internal memory
When the SD Card is In the device, the internal memery is disabled. Remove cam from connection, remove SD Card, re-connect camera. This should Resolve you problem. Be sure to have the correct drivers loaded before accessing card or camera.
Good Luck...
DoLittle
May 12, 2008 | Jazz DV-179 Digital Camera
Jazz dv-179
Yes you can. Any sd card will work. (Not micro sd)
I've tryed many sd cards in my Jazz dv-179
Mar 17, 2008 | Jazz DV-179 Digital Camera
SD memory cards
Has another SD Card worked? is this the first you card you tried?
Be sure you have the correct type (size) SD card, there a couple of SD card types, micro (very small, etc.). It should go in only one way, does it fit and install easily? It should SNAP into placye.
A SD card is supposed to ONLY GO IN ONE WAY, the correct way.
It should SNAP in. Try to insert it in a different way very carfully.
DAVID
Jan 28, 2008 | Jazz DV-179 Digital Camera
Jazz DV-179 Digital Camera Logo
61 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
