Question about Honda 8 HP Engine
I have a honda GX240K1 on a BCS tiller. The engine seems to defy reason. I have adjusted the governor, set the max speed screw, adjusted the idle speed and have achieved some success but cannot seem to control max RPM's. The engine max's out at over 5K. I have tried about everything I can imagine yet nothing seems to fix it. Spec's say that it should idle at about 1400 Rpm yet it seems to idle best at about 1800-1900. I am using a EZ328 instrument to check the engine RPM and it's reading is erratic. It seems impossible to get the engine max speed set to what the book says it should be. Max at not over 4,000rpm yet it goes over 5,000- and even approaches 6,000 (according to the EZ328) It's a wireless RPM instrument that senses the spark on the engine plug wire. I am fearful of running the engine for extended periods because I think it will literally blow apart.
  • linwoodsprou Jun 06, 2010
    The problem is not the instrument, it is the engine. Read the original post.
  • 10,865 Answers
Hello. It sounds like the governor is either out of adjustment or in need of replacement. I agree that you should not run this in this condition or you will have a much larger repair to do. I would replace the governor. J.
Posted on Jun 06, 2010
  • 2 more comments
    There is one thing that is unclear to me concerning the adjustment of the governor.
    Which of following procedures are correct?
    1. Remove the gas tank (I generally take the bolts out and just let it rest on the engine high enough to make the adjustments)
    2. Loosen the bolt that holds the governor rod to the governor shaft that comes out of the engine.
    (the next steps are what is unclear from the service manual)
    3 Turn the governor shaft clockwise until it stops
    4. Do I push the throttle to 'full throttle" position or set it at the "Idle" position? In other words do I push the control rod for the throttle away from the carburetor or towards it?
    5. Next what direction to I push the governor rod that is attached to the governor shaft that comes out of the engine towards the carburetor or away from it before tightening the bolt.
    The manual is totally unclear in this procedure.
    I had perceived that the governor gear inside of the engine may be the culprit but seriously did not want to break the engine apart for fear of difficulty of re-assembly may well be difficult. I have done many things in the course of my forty plus years as a tradesman - but this is one task that I have minimal experience in. It may not be a big deal, I just don't recall having tread that water before.
    I have worked on far more complex pieces of equipment in my lifetime and yet this little motor seems to defy my life skills. I seriously want to conquer it that I might move on to another quest. I have 9 of these little tractors to rebuild. This is only the second for this year and no two of them are identical. Its the challenge of perfection that I like. :-)
    click on the below reference to see what the instructions are in the Honda Manual. (I hope this works I've never done it before - set up a link like this one)
    Photobucket
    nope, guess it did not work.
  • linwoodsprou Jun 07, 2010
    I do believe I have discovered the secret to adjusting the governor. Simply move the throttle to 'full throttle' position loosen the bolt on the governor rod turn it counter clockwise and then begin the process of loosen/tighten and move the shaft until the fine balance of adjustment is accomplished. I must say that those who write the Technical manual for Honda could use a bit of instruction on how to write procedures that are easily understood. I am no novice when it comes to service manuals. I have written many Technical Reference manuals myself and this one is just too brief to be clear. The arrow on the illustration drawing shows turning the shaft in the opposite direction needed to make the proper setup. This is not to mention the other arrows showing movements that are simply not to be done.
    I wish someone at Honda would correct this procedure - it would do a great service for those who repair these engines. I have wasted several days and many hours on the WEB searching for a proper setup of this engine governor. Nothing I found actually worked. The revised illustration that was given to me by reference from the current expert was the nearest thing to a good procedure that I found. Yet it even leaves something to be desired.
  • 12,061 Answers
When I first read this post, I was struck by one statement in particular, that, "I am using a EZ328 instrument to check the engine RPM and it's reading is erratic" (sic) Now the thing that I focussed on was the ERRATIC. Having been an engineer now for over 35 year when ever I see or experience anything erratic, I have learnt to CHECK YOUR INSTRUMENT is calibrated and working by checking against a know good. This is a MUST DO. Only then, can we "Trust" our instrumentation. Unless empirical evidence is ALSO to hand, then it does need to be calibrated. Also, with instrument that use WiFi this can have widely variable reading, I have experienced. If everything isn't just so, I feel an OPTICAL trigger is in my experience much more accurate, than anything else. As if there are any problem with the ignition spark etc, that may interfere with the readings. I feel if you have done all you say, and all setting are done and you have set it up by the book, what else is there? Well... It maybe electronic, hence the erratic reading? perhaps the Governor circuitry is not working properly due to a semi faulty sensor? Or perhaps the "Micro" brain, just isn't working 100%, an input may have been spiked etc. http://www.repairmanual.com/catalog/61ZH910 Above is a link for a, pay for, generic repair & service manual I also would get your service manual one too, and they are worth their weight in gold i find. they are just indispensable, they also have troubleshooting steps too, maybe even this is a "know about issue"?
Below is a free service and repair maintenance manual this may help. http://www.scubaengineer.com/pictures/honda/honda_gx_k1_service_manual_240_270_340_390.pdf
    Electronic Specialties (ESI328) EZ Tach Plus
    This device is new. It is the second one I just purchased. I tried the 320 model but learned after purchasing it was only dependable on large automotive style engines. This unit is supposed to work on everything from string trimmers to large automotive style engines. Again,it is brand new. It has (the manufacturer claims) and accuracy of within 10rpm, I am somewhat confident that its reading is correct (even though it is a bit unstable). It is a wireless device that senses the spark on the ignition wire. I am confident that the instability of the reading is caused by not knowing the magical distance from the ignition wire to the spark plug. I can get a fairly good reading what I cannot do is figure out why this engine is running at such a high rpm. :-(
Greetings. I have a eu2000 honda inverter with the following problem. The high generator runs too fast, when the idle is activated, slows down a bit, but does not increase
on the governor control back to the carby , there is a screw that adjusts the spring tension for the governor arm
that screw is the adjustment for engine operating rpm not the idle screw
Dec 05, 2016 | Honda Electrical Supplies
Honda gx160
Kescorpio56:
Check your throttle and choke settings. Something is causing the throttle plate in the carburetor to remain open or the governor is improperly set. I would reset the air/fuel mixture screws to one and a quarter turns out and back the idle screw all the way out. Make sure that the throttle cable operates the throttle properly and check the governor setting and reset the governor setting if needed. Start the engine and adjust from there. When the engine starts, adjust the idle screw until the engine idles. Adjust the fuel/air mixture screws for the best idle. Then run the RPM up and adjust the fuel/air mixture screws for the best run/idle combination. Don't forget to adjust the governor if the engine runs too fast or too slowly.
May 31, 2013 | Air Tools & Compressors
Honda 25 cc 4 cycle mini tiller how to adjust carburator
With one screw you can adjust the idle speed, and with the second, located under the carburetor you can adjust the running or load speed.
Mar 22, 2013 | Honda 25cc 4-cycle Mini Tiller
What is carburatoradjustment on a modle 358.355140
This is your carb:
http://c.searspartsdirect.com/lis_png/PLDM/00051166-00002.png
Here is the parts list:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358355140/0247/1503220/00051166/00002?blt=06&prst=0&shdMod=358355140
The initial settings are 1.5 turns from just closed.
Adjust the "L" Needle (low) so that the engine does not stall or hesitate when the throttle is increased.
Next run the engine at MAX speed and adjust the "H" Needle until it just barely stops missing and you get MAX speed.
Recheck for stalls or hesitation from idle... Adjust L Screw again if necessary until it no longer hisitates or stalls when throttle is increased.
Recheck MAX speed and adjust as necessary.
Set idle...speed with top screw.
L and H acrews are on the side.
Thanks for choosing FixYa,
Kelly
Sep 14, 2011 | Craftsman Garden
How to adjust a fuel governor for a 3750 watt coleman generator
With parts list in hand, look at reference #21 governor arm and reference 89/90 adjustment screw. This adjustment will increase decrease engine speed. I would use a meter with hz setting to set engine speed to achieve 60 cycles. Sixty cycles on the meter would indicate that the engine is turning 3600 rpm which is max. If all working correctly, voltage should be around 120v at 3600 rpm and 60 cycles. Good luck
Aug 02, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
My pilot valve needs to be adjusted. it does not idle the engine down.
If the pressure is set about right (cuts out pump at about 125 ), most likely problem is actuator at the engine /governor mech. or idle screw turned in too far. With engine off and about 100psi in the tank, flip unloader lever at pilot valve. Flipping the lever up then down will allow you to watch the actuator in action (take the air filter off at engine). The acutator should not leak air(has oring inside) and should move the governor against speed adjustment screw then away. If no leaks and governor arm moves as needed, adjust idle screw at the carb. Many time the idle screw is adjusted in too far to prevent engine from stoping when cold or other problems cause engine to stall. Good luck
Jul 11, 2011 | Dewalt 5.5HP 8GAL Gas Wheeled Portable...
How do I adjust(set)the engine speed govenor on an Atco 114cc engine.
Some ATCO carburettors have more than one hole for attaching the throttle cable to the governor pivot, which will allow some variation of the speed setting by moving to a different hole.
Just before the throttle cable reaches the governor pivot it passes through a metal lug (separated from the pivot by a spring) here there is threaded screw on the throttle cable - loosen or tighten this to adjust running speed.
There is also a throttle stop adjusting screw which on the side of the carburettor which you can adjust to set the idle speed.
Feb 22, 2011 | Garden
Troy bilt bronco model # 12180starts & idles fine. How do you set or fixthe governor . It runs at idle speed all the time. I can force the governor open and it with run fine until I turn loose of the...
clean and lube around butterfly arm and "windvane' under engine cover.most governors are controled by air coming off finns on flywheel also check to see if you have return spring broken or missing
Mar 25, 2010 | Troy-Bilt Pony Garden Tiller
Adjusting mtd carb. i there a set turns for the adjustment screws
Basic screw adjustments to start with are 3/4 of a turn from the farthest "in" setting. Don't tighten down on the screws too hard, turn down just enough intil they stop, then turn out from there. After engine starts, you can fine tune the idle speed and then the high speed crews.
Feb 18, 2010 | Mtd Products Yard Machines 158CC Tiller
High / low speed jets both turned into base completely, how many rotations out before fine tuning for performabce.
Hello:
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Garden
Honda 8 HP Engine Logo
319 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
