Question about Ruud UAMB Air Conditioner
Do not feel air flow from ruud air conditioning
  • 3 Answers
Problem can be several things. Check air filter first. If filter is clean, contact a licensed air conditioning contractor.
Posted on Jun 06, 2010
Heater will not start
If you are getting air conditioned air when you are supposed to be getting heat, the compressor is working but the valve that reverses the refrigerant flow for heat to be created could be stuck in the default postion which for a Ruud is air conditioning. There is also a special output on your thermostat to activate the heat cycle and reverse the valve.. Maybe that is not working and the cause of your anomaly.
Nov 24, 2013 | Ruud UAKA037 Air Conditioner
Ruud achiever seer 10 air condioner not blowing cool air
need more info, touch the copper lines going into the unit do u feel any flow? Go outside do you see any fans turning? number of things you can do. Get back to me
Aug 12, 2011 | Heating & Cooling
Ruud achiever 10 froze up but the fan works but not getting cool air flow through house. what is causing this?
The most common things that will cause a system to freeze up are:
1. Dirty air filters
2. Dirty evaporator coil
3. Indoor fan motor not running
4. Blocked/restricted return air flow
5. Low on refrigerant charge ( most common)
I would start with the filters. When the system is froze up, turn off the "cool" and just have the fan set to on. Make sure there is no more ice anywhere, turn the system back on and check your air flow throughout the house. If it feels normal, then filters, return, and fan should be good. The outside unit will have warm to hot air coming out of the fan if the charge is good enough, but that's not a perfect way to check, you will need gauges and a temp reader with knowledge of super-heat and sub-cooling to check the charge the right way. Hope this helps and good luck!
Jun 22, 2011 | Ruud Matching Split Air Conditioner
We have a ruud heat pump that is developing frost inside it. What should we do?
Frost on the outdoor coils is normal...it will defrost them as neccesary...
Frost on the indoor coils when in cool mode is bad and indicates a low charge or a low air flow condition...
heatman101
Dec 02, 2010 | Heating & Cooling
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Sep 13, 2009 | Ruud UBHC Air Conditioner
Not enough air flow coming from the vents on the second floor.
If you feel like increasing your blower motor speed you can do this. Go to the air handler take the cover off to expose the blower motor. You will see a circuit board that has the blower motor wires going to it. Using your flash light look at the board and locate the terminals that read Cool Heat Park ... Now the Cool terminal should have black colored wire going to that one. Now locate the Heat terminal if it has red going to it and maybe blue sitting on the park terminal then swap the two around, blue is like med speed on the blower. Where Red is low speed. This will increase the blower about 50 rpms. You can even read your blower motor and get the speeds more detailed. You have a big house your unit is I bet a 4 ton A/C and 125,000 btu furnace. Probably has 1600 rpm motor. This is one solution. You have a up flow model and when you open the furnace cabinet up you will be able to see the specs. on the furnace. Let me know how that goes ken here in Kansas
Jan 13, 2009 | Ruud Central System Air Conditioner
Air Conditioning
Open the access panel on the air handler in the attic and take a look at the evaporator coil. If you have no airflow, and you just changed the air filter, then you probably have a buildup of airborne crud on the coil that's blocking airflow. If you do have a layer of buildup blocking airflow through the coil in the air handler, just take a $5 fin comb and scrape all the crud off the coil fins. This can make a dramatic difference. Hope this helps! ;)
Aug 09, 2007 | Ruud UAKA030 Air Conditioner
Ruud UAMB Air Conditioner Logo
130 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
