Question about Kirby Heritage II Vacuum
What size motor do they have - Kirby Heritage II Vacuum
  • 3 Answers
120V, 50/60HZ, 4.5 amps with carpet beater attachment; 5.5 amps with the hose attachment.
Posted on Jun 24, 2010
Need to locate fein carbon brush 31332843000 for a turbo ii 9.20.25? Suggestions even for generics?
carbon brushes for electric motors come in all shapes sizes and lengths as the motor manufacturer uses generic units in the manufacturer
go to an appliance repair shop or a motor repair shop and brushes that have the same connection ( pig tail braid , solder on etc) and are close to the dimensions can be filed down to dimensions to suit
Oct 31, 2017 | Fein Vacuums
So I can remove the motor and purchase the correct driver, what type and size torx screw does it use?
Fran,
If I remember correctly, I believe you need a #20 Torx bit to remove and re-install those screws. You can usually find a kit that has multiple size bits in them at any hardware or tool store. You might even be able to get individual torx screwdrivers as well. Hope this helps!
Feb 17, 2016 | Oreck XL® Classic Bagged Upright Vacuum
Why is the new belt on my dirt devil featherlite repeatedly slipping off? Everything else on it works fine and the b elt is the correct size.
Hello! There is no other part that goes on the motor shaft after the belt is put on. The tension of the belt keeps the belt from slipping off. If you have a brand new belt that keeps slipping off you may not have the correct belt for the vacuum. Be sure you replace with a genuine Dirt Devil belt and the specified belt style for your particular unit. Hope this helps! If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Apr 28, 2014 | Dirt Devil Vacuums
Hoover #u5753-caught a dime size piece of plaster in my machine. turned it off, and now it wont make a sound
It has a bound up motor and will not turn when turned on. Do not force it to start as the motor can burn out completely. You need to get into the intake section and dislodge the fragment.
Feb 24, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My filterqueen majestic is 10yrs old and just started to spark and smell of burning ive took it apart
If you have a burning smell from the motor, your motor is shot. You should be able to buy anew AMTEK Lamb motor for about $85-110 US. Request a double ball bearing motor as it will have a longer life span.
Also buy a fresh internal filter kit. There will be a small 5 .5 inch filter disc inside the cone protecting the motor in the event that the cone tears. Replace it .Also save and reinstall the small insulating disc that sits between the top of your motor and the screen at the top of the vac. This is to prevent electric shock. This disc is the size of a coin.
Post back if you need more help. Wiring is very easy. Do NOT twist your wires before installing into the connectors, twist the connectors, then tape to be certain they are on tight.
Nov 04, 2009 | Filter Queen Majestic Canister Vacuum
Majestic filter queen vacums
Your belt is either stretched or the wrong size or the brush bushings are worn and allowing the brush to wobble or the motor is loose in its housing. You need to check all.
Rotate the brush and try to wobble it from the pulley end.
Flip the belt inside out, it if appears cupped, cracked or shiney and slips easily on and off the brush it is stretched. Generally this unit needs anew belt evrey 6 months, broken or not, they get hot and stretch. Do not buy a new belt by matching size, a worn belt can be 20-30% oversized and not broken but totally useless.
The motor shaft should be cleaned with W/D 600 grit sand paper. Motor should have no wobble in the shaft
Sep 09, 2009 | Vacuums
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Shopvac motor not working
Then the motor brushes may be worn, or a winding is open circuit. Sears is pretty good at replacement parts, and they probably can supply just the motor assembly.
Jul 26, 2008 | Vacuums
Looking for Replacement Motor for Bosch Ultra 1450W Canister Vacuum
If you are finding BB's. then the bearings are bad. You could pull the motor and take it to a place that rebuilds motors to see about replacing the bearings. If it is a Lamb or amtec motor, there is a number stamped on it, you can match up another motor with that number. Go to a place that sells Vacuum repair parts and they maybe able to get you a new motor.
Dec 24, 2007 | Vacuums
Vacuums Logo
51 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
