Question about HP LaserJet 4345mfp Printer
I have an HP Laserjet 4345mfp. Right now the paper that comes out as someone prints has a corner folded. It is obvious to me that there was a paper jam but I don't see any paper. What would be helpful is a diagram of the paper path so I can inspect it. Is there a diagram of the paper path?
I have the same issue - anyone?
Posted on Nov 16, 2010
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
Slow print come out with hp laserjet 4345 printer
dear friend,
for slow print many reasons:
1- check tray adjuster
2- check tray customs or standard lock( it will be right side tray lock)
3- check your printer driver
4- check printer firmware
5-check printer fuser
these are the reasons printer work slove
Mar 28, 2014 | HP LaserJet 4345mfp Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
HP LaserJet 1320 folds over top left corner of every page printed
I see this problem alot after a paper jam occurs and someone has pulled the stuck paper out. There is probably a piece of paper stuck in the printer somwhere. If you open the front toner door and take the cartridge out, you will see a roller at the bottom front. DON"T touch the roller but take it out. You may find the paper there!
May 24, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320tn folds the upper right-hand corner of the page
Check carefully for any small scraps of paper caught in the paper path. Do a 1/2 way test, do a print job, listen for the paper to get just under the toner then quickly open the front of the printer (may take a few tries) see if the paper is folded there or if it's happening later that way. If it is folded before entering the fuser, you probably have a small piece of paper in the paper chute somewhere. If it's not and folds later, the fuser is probably worn badly.
Feb 09, 2009 | HP Laser Jet 1320 Printer
HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Oct 09, 2008 | HP LaserJet 4350dtn Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Hp lazer 1300
The Printer's Fixing Film on the fuser assy is broken. It should be replaced. Go to a Service Center and replace the fault part.
Mar 05, 2008 | HP LaserJet 1300 Printer
Pale print on PDF files
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
Jul 25, 2007 | HP LaserJet 4345mfp Printer
HP LaserJet 4345mfp Printer Logo
113 people viewed this question
Seeker5211
Seeker5211
