Question about Sony Handycam DCR-TRV250 Digital Camcorder
C-31:22 FLASHING AND DINGING
C-31:22 FLASHING AND DINGING --- HAVE TRIED SMACKING IT SOMETIMES I GET C-31:23 CODE& C-31:40
  • 115 Answers
Don't smack that'll just make it even worse there isn't much you can do to fix it so justbget a proffesional to get it repaired for you goodluck...
Posted on Jun 06, 2010
  • Mohammad Alavinejad Jun 20, 2013
    hi sir, please explain for me,how can i fix it,i can do it. thanks
My handycam is flashing c:31:23. What can I do to fix this? Thank you.
First, try setting it on it's side and holding rewind. If that doesn't work, try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Jul 18, 2011 | Sony Handycam DCR-TRV140E Digital...
I have a Sony CCD-TRV308 NTSC that flashes the following fault codes: C:31:40, C:31:22 and C:31:23. I have repeatedly removed the tape and the battery in an attempt to clear this. It will run for a few...
The 4-digit error code consisting of an alphabet and numbers, which blinks at 3.2 Hz is dislayed on the screen when any problems occur. This 5-character display indicates the "repaired by:", "block" in which the problem occurred, and "detailed code" of the problem.
The error code C:31:22 and C:31:23 indicates T reel fault and S reel fault respectively. Load the tape again, and perform operations from the beginning.
The error code C:31:40 indicates FG fault when starting drum. Load the tape again, and perform operations from the beginning.
Furthermore, press and hold the power button for 30 seconds then try using the Camcorder.
If the issue persists then service is required.
Sep 17, 2009 | Sony Handycam CCD-TRV308 Camcorder
SONY DCR TRV350 C31:23 and C31:22 flashing code
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jun 15, 2009 | Sony Handycam DCR-TRV240E Digital...
Service engine soon light
You need to have the vehicle scanned or pull the code out with a code reader,and address/fix the code.If you do not repair the problem,you can clear the code,but the service engine light will come right back on.To clear the code,you can disconnect the negative terminal on the battery for at least 20 minutes,then reconnect the battery,but the car is going to be hard to get to idle,because sometimes the computer has to relearn how to idle the engine without stalling.Good luck.
Jul 10, 2008 | 2002 Buick LeSabre
Error code C:31:40
After looking up the error code C:31:22, I saw all of the solutions for slapping the side of the camera. Slapped it 4 times, then the error code switched to C:31:23. Same solution... Whacked it 4 times, then the error code switched to C:31:40. Again, whacked it 4 times. Opened it up, turned it upside down and a rubber roller dropped out of the camera. I could see where it went, snapped it down on its metal peg and it works fine. Looks like its the rubber rollers that guide the tape that gets stuck. Before whacking it, make sure the RUBBER roller moves freely. Good luck!!!
Apr 14, 2008 | Sony Handycam DCR-TRV240E Digital...
Sony handycam CCD-TRV308
I was getting the same code and a dinging noise. I tried a cleaner and I tried letting the camera dry out...it wasn't wet! Neither worked. SOOO...Don't buy a cleaner. Look inside camcorder and make sure both reel turners are equal in height...they can slide down. Turn both of them...one of mine was down and also did not turn to make contact with tape. We got it to turn and the message C31:23 and the dinging quit. The stripes/bars also went away. Camera1.gif instantly worked like it used to. Good luck.
Dec 31, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Flashing yellow arrow
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Dec 10, 2007 | Sony Handycam DCR-TRV250E Digital...
Has error
Dec 24, 2006 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam DCR-TRV250 Digital Camcorder Logo
1,188 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
