Question about Philips 51PP9303H Rear Projection Television
The display on my phillips hdtv 51pp9303h
The display on my phillips tv is off. basically the colors are off and the dispay is a little blurred. it looks like it's playing in 3-d but with no glasses.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
TV has multi color lines and a circle when I turn it on
Sony rear-projection TVs provide a large-screened entertainment solution for your home or office. Unfortunately, color problems and yellow and blue spots and saturation can occur on the face of the Sony rear-projection TV. These problems can be the effect of damaged cables, electronic interference from other devices or dirty lenses on the inside of the rear of the television set. You can troubleshoot for these problems and make satisfactory repairs without the help of a repairman. No experience with Sony rear-projection TVs is necessary.Step 1
Check the audio/video cable that connects the Sony rear-projection TV to the cable or satellite receiver. This black cable has a number of multi-colored plugs on each of its ends. Ensure that this cable is not visibly damaged in any way, and that each of the plugs is in good shape and is not bent. A damaged audio/video cable will negatively affect the quality of your rear-projection TV's display and may lead to yellow and blue saturation problems and various other display irregularities.
Step 2
Ensure that there are no other high-powered electronics in the close vicinity of your Sony TV. Speakers, computers and other similar electronic devices use a large amount of power and in turn may give off a lot of electronic interference. This interference can cause problems for your rear-projection TV's screen, such as color blurring and similar color issues. Move any such potential devices to an area that isn't as close to your Sony TV. The color blurring and yellow and blue saturation problems should then decrease over time.
Step 3
Unplug the TV if problems persist. Ensure that the Sony is completely disconnected from all power sources. This is for your safety.
Step 4
Place a towel on the floor of the area where you are going to operate on the TV. Carefully turn the TV facedown on the towel, so that the rear of the TV is facing upward.
Step 5
Remove all the screws from the back cover of the television set using a Phillips screwdriver. Remove the back cover piece by working around the edges with your fingers and gently prying the piece off.
Step 6
There will be three upright lenses in the back of the television. Cleaning these lenses can alleviate picture quality problems and color blurring. Use a soft cloth and soap and water to clean the lenses of the television. Avoid using any other cleaning solutions, as soap and water is the only universally recommended cleaner from rear-projection manufacturers like Sony.
Step 7
Ensure that the lenses are dried. Replace the back cover of the rear-projection TV and reinsert all screws using the Phillips screwdriver.
Jun 19, 2016 | Televison & Video
Double images-picture on tv is in unalligned red and green colors
You need the Phillips DPTV305 - DPTV345 Chassis convergence repair kit which is available at the following link. the kits contain the parts and detailed instructions on how to do the repair.Just click on the phillips repair kits page.
http://tvrepairkits.net/
Jun 23, 2009 | Philips 60PP9202 60" Rear Projection...
Slight yellow tint to the color.
replace the coolant in the picture tubes that will restore the color and the clarity. Heres a link to the kit which has the coolant and step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 24, 2009 | Philips 51PP9303H Rear Projection...
Bought 57'' philips tv picture fine but red overpowering
should be a knob on the back inside has 3 one for each lamp red green and blue just turn the red down a little
Mar 26, 2009 | Philips 51PP9303H Rear Projection...
Troubles with phillips projection tv. It is showing about a 6 Inch blurring color at the bottom of the screen and blurred color streaks throughout the screen, what could be the problem?
you need the DPTV305 - Dptv345 Convergence repair kit available at the following link. Its listed under the convergence repair kits category, comes with all parts and step by step instructions with pictures so you can do the repair yourself.
Here is the link.
Oct 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Phillips TV
What is the purpose for resetting the tv?
Aug 08, 2008 | Televison & Video
Changing factory dispay settings
you can cahnge it a little
go to menu
then settings
then display settings
you can change text style and color
Jun 13, 2008 | Samsung SGH-t219 Cellular Phone
Phillips 60PP920217F Convergence Problems
Sounds like you are on the right track, yes you need to change also the return resistors, they will be located close to the convergence amps you have replaced. There should be several resistors standing up around the IC's, you can lift one leg and check all resistor and the ones with same color should be the same resistance. Another way is to just replace all of them. I don't have a location for you but I have replaced a similar set 51pp9303h/17 and I think the boards are similar. So if you are this close then by all means replace all the resistors, You can go to MCMelectronics, Bluestar-online.com, Tritronics, etc. To get part and also you can buy schmatics on line. Don't quite remember site but you can search. I think it was 11.99 for downloading for my set. So hope this helps.
Sep 19, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
