Question about Car Audio & Video
Cannot get it to work with all wires hooked up- good fuse (2). Is there a fuse on the inside that I can check? There is no power on light, and nothing coming from subs. What can I look for?
    Problem Solver:
  • 19 Answers
Depends on what kinda amp you have there could be a fuse inside but rather perfer to let a professional check it out . make sure ur remote wire is sending power to the amp that can cause ur amp not to turn on. and check with a volt meter for 12v from power wire
Posted on Jun 06, 2010
My 1999 Honda shadow 750cc won't start
Ok, been awhile since I played with a Honda, but I believe in the KISS method.
#1 go buy a cheap $10 meter at harbor freight, Menards, Home Depot, Lowes, etc, etc. You can't just look at a fuse and say it's good, been there done that...LOL
#2 There used to be a fuse in the headlight bucket, check to see.
#3 real simple, did you leave your KILL switch off??? If not the check voltage to kill switch, make sure you have power coming out.
#4 check the ignition wire for the starter, when key is in on position or (start) position, make sure you have voltage. If you have power, follow it to your starter leads and kill switch.
#5 check voltage at your coils, Check for voltage coming out of coils. Just because you may or may not have spark, doesn't mean you have enough to start bike.
When you hooked in the LED's you either shorted wires to blow a fuse, over loaded a wire and possibly burned it in 2. Or you dislodged a connection someplace. Go back over everything you did again, and go buy a meter.
May 22, 2017 | Honda Motorcycles
Have no brake lights I changed the stop switch what else should i look for fuses in cab looks good
Without knowing the kind of vehicle you have, just start with basics first. Take a test light, hook to good ground (check light works by other fuse power to light) and check each wire at the brake light switch. Should have power on one of the wires. If you don't then you need to check between fuse and that wire. If you have power at the switch, step on brake and check for power coming out onto the other wire. ( that checks to make sure switch works). If power goes thru then you need to trace that wire toward your brake lights for open or for bad ground. Check for power at the light may have bad ground keeping lights from lighting. This should get you started. This is as much info I can give without knowing more on vehicle.
May 18, 2015 | Cars & Trucks
2006 Chevrolet Colorado,only left front turn signal works,not even hazard are working.
first check the brake light fuse it powers the rear bulbs.
remove and verify that all bulbs are working. note the wire colors going to the bulbs. replace as needed.
next check the turn signal switch. if broken replace.
sometimes switches break on the inside so measure from the power lead to the outputs. The wires going to the bulbs. easy because they are on the bulbs you checked.
if you have towing package there will be a connector to hook up lights on the trailer. Inspect for bare wires or cuts in the insulation.
good luck
Feb 21, 2013 | 2006 Chevrolet Colorado
Air and heat blower will not come on. 1998 sonoma 2.2l
start by checking fuse. if fuse is good, aquire a test light, check the test light on the battery to make sure the test light works. Power to ground = light. access blower motor under pass-side dash panel.(probablly have to remove underdash cover, secured with pop-in style fasteners.) locate blower motor. 2 wires w/connector Purple-power, black-ground. check for power at purple w/test light on known good ground, with ign on, and blower switch on high. if it has power, hook clip of test light to a power source, ( + on battery w a jumper wire) and probe black wire, with test light. if no light, jumper that wire to a good ground. if it lights, you have a bad b-motor. if no light on power side of blower motor, and fuse is good, check power to swith. blower circuit may have 2 fuses. 1 for high and a 2nd for the lower speeds. if switch has power to it, and power is transfered to another wire when switched, suspect the blower motor resistor. James White, White Automotive, Hopkins Mo. ASE tech, 17 yrs exp.
Feb 06, 2013 | 1998 GMC Sonoma
My power acoustic protection light stays on i got good ground and a good positive connection, no speakers or RCA's hooked up, what could it be
Are you fused close to the battery with a 30-50 amp fuse block?
Ground unit also to most closest suitable location!
Is your power wire undersized?
Check units fuses you may have blown one hooking it up!!
Good luck
Feb 15, 2011 | Power Acoustik LT-1920/2 Car Audio...
The main problem I have having is I am getting power to my AMP but no power to the subs. I tested my AMP and subs in another car and everything worked so I know my hardware all works fine. I had someome...
okay , well you need to make sure all your conections are in the right spots, and that your IN LINE FUSE, between your amp and battery, the big glass one is not burnt, just take a look at the metal piece inside , if its a sold metal piece its good, if its burnt in half like a broken bridge it needs to be replaced. the next thing is the fuse on your amp, you need to make sure it is not burnt also. Check your remote that it is hooked up to the right wire. then check that your sub/speaker wires are connected properly and secure. YOUR GROUND WIRE IS HUGE HERE also. MAKE SURE IT IS GROUNDED TO A GOOD SPOT, YOU MAY HAVE TO MOVE IT AROUND A FEW TIMES TO FIND A GOOD GROUND!!!! if you check all of these things, it should work fine.. you can fiddle with your amp and bass settings levels. turn em up so when it works you know it, but not too much you dont wanna blow nothing :)
Mar 12, 2010 | Car Audio & Video
My amp does not work
Did you check to see if its grounded well? Try grounding the amp to the battery, also check fuses. I'm not sure how you hooked it up, but I usually connect the amps directly to the battery with a heavy duty fuse. Also try the remote wire, from your cd player to the amp. Thar are usually 2 different remote wires make shure thair hooked up right, if thats all good and the amp power light isnt on then it sounds like your amp is bad.....
Dec 11, 2009 | Kenwood Car Audio & Video
No power to the fuse box
i think it has 2 boxes. but id look at the ignition switch. do the headlights work. and is there a big fuse very close to the battery you might be over looking. and a lot of time the fuse box gets power from the starter. check to see if you have power there. and does this truck turn over good luck
Nov 23, 2008 | 1986 Suzuki Samurai
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
