Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
The water didn't drain . I washed a broiler pan and used pot scrubber and heated dry. I opened the dishwasher during heated dry and greasy water is still in the bottom of the dishwasher. Could it be a grease clog?
  • 523 Answers
Yes take a smaller hose and put through the drain hose then push drain/cancle
Posted on Jun 06, 2010
What is the sequence to reset kenmore dishwasher 665.16819992? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, water Heat, no Heat dry, delay Hours,...
You haven't said why it needs reset, so possibly it can't be reset if there is a mechanical or electrical problem with a part in the dishwasher.
Here is a link to a page on YouTube. They usually have good repair videos and how to videos:
https://www.youtube.com/results?search_query=how+to+reset+kenmore+dishwasher+665.16819992
Mar 04, 2015 | Kenmore Dishwashers
Tip
Tips For Dishwasher for its safety and getting dishes cleanest
A) If your household is small, try gradullay accumulating a full load of dishes and rinsing as you go, instead of stacking dirty dishes in the dishwasher.
B) Cleaners and some elbow grease will always get pots and pans cleaner then the pots and pans cycle on the dishwasher.
C) Good crystal and china should be hand washed and not placed in the dishwasher since the detergents and jostling can damage them quite easily.
D)It can take several hours for dishes to dry when using the no-heat dry option the dishwasher. Try propping the door open to speed the drying process.
on Dec 14, 2009 | Dishwashers
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Gold Quiet Series Plus, Model GU940SCGT3, not working. It ran a cycle, cleaned the dishes, but the water didn't drain and the "CLEAN" light is stuck on. It is now...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Kenmore elite dishwasher. The Pots and Pans red light is flashing and the Heated Dry light is solid red. Nothing I do will change that. I've tried pushing any combination of buttons and ...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 19, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
I have a greasy buildup on my dishwasher filter.
It is the grease left on dishes or pots & pans. It can be cleaned off using a good regular dishwashing detergent like Dawn in the sink, not in the dishwasher. To prevent it, scrape the dishes & pots better, and if possible, turn the temperature of the hot water up a few degrees. You should also change dishwasher detergents to a liquid, with a built in water softener.
Sep 05, 2009 | Frigidaire Dishwashers
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
140 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
