Question about Samsung 206BW Monitor
Problems with digital cable
My new Samsung 206BW monitor doesn't seem to recognise the signal when I use the digital cable supplied with it (says check signal) and yet the analog is just fine. Am using Nvidia 8800 GTX card and the drivers are all up to date. Any idea what's wrong (aside from maybe a faulty cable)?
Thanks
Check the source on the monitor, there's a button for it on the front.
Posted on Apr 23, 2008
SYNCMASTER 206BW PROBLEMS I started having the same problem about 2 weeks ago. The screen flickers on and off for about 15 minutes. Although I can see windows is running in the background, the screen...
Common problem with just about 905 of failed LCD monitors; bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 26, 2010 | Samsung 206BW Monitor
Monitor Flicker Samsung 226BW
Look for bad caps in the power supply just like all the failed SAMSUNG as shown here: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Sep 05, 2010 | Samsung 206BW Monitor
Monitor fleckering
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 28, 2010 | Samsung 206BW Monitor
White screen on a Samsung 206BW after it fell onto the floor
Something is wrong inside the monitor. I would call samsung support and get an answer from them. You could probably trade your monitor in aswell if its still under warranty.
Apr 18, 2010 | Samsung 206BW Monitor
MONITOR WON'T POWER UP
That will be my first place to check, see pictures of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 25, 2010 | Samsung 206BW Monitor
Samsung syncmaster 206bw turning on and of, light flashes on for 4 seconds, then off for 2 repeatedly i can see windows is working fine in the background during the 4 second gaps while the monitor is on...
If you have soldering iron and can place an order at DigiKey.com (and are willing to get your hands down on this), this is a rather easy fix with some direction. You basically will be replacing some failing capacitors inside the unit.
Jun 16, 2009 | Samsung 206BW Monitor
Samsung 206bw Monitor Flashes/Flickers on and off
Set the Hrts to 60 in Display Properties in control panel
Jan 14, 2009 | Samsung 206BW Monitor
After 30minutes and over,monitor display disappear
I had a similar problem with the same model; the cable connection into my computer was not good. Try fiddling or replacing the cable.
Oct 24, 2007 | Samsung 206BW Monitor
Samsung 206BW Monitor Logo
260 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
