Question about RIM BlackBerry Bold 9000 Smartphone
My phone was working at night, I plugged it into the wall charger while it was still on. I woke up the next morning, disconnected it from the wall charger, and the phone immediately shut off. I plugged it back into the wall charger, the red led lights up for about 30 seconds, then the light turns off, then 30 seconds later screen turns white with a battery image and a blue lightning bolt through the battery. I hit the power button, but the phone will not start up
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be a battery issue; the battery has gone bad because of overcharging and needs to be replaced. I have blackberry storm and it hardly takes 1hr to get it completely charged up however, as you left it on charger for whole night so this might have blown off the battery. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
  • anthony_capp Jun 06, 2010
    I went to the AT&T store and they tried putting a replacement battery in and I still experieneced the same symptoms with the lightning bolt.
  • Rylee Smith
    Rylee Smith Jun 06, 2010
    As I said
    earlier this issue happened due to overheating. While you bold is turned on
    take the battery and then SD card out. Then place it back after 30 minutes and
    see if it works, if it does not then try to install the software. If still the
    issue is not resolved after doing all this then it seems that you have to get
    its firmware updated or use warranty.
    Thanks
    Rylee
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
My phone will not turn on
take the battery off and reboot. if not maybe it's seen it's last day.
Sep 07, 2012 | Samsung Exclaim M550 Cell Phone
I have a Storm 9530. One evening I plugged my phone into my wall charger (not computer) to charge and when I woke up the next morning... low and behold the infamous battery with red line showed on the...
It could be the charger, the phone's power interface, or your battery. When you plug the phone in to charge it, does it recognize the charger and show the lightning bolt symbol for charging?
If you use your computer's USB port to charge it instead of the wall charger, does it act any differently?
Aug 16, 2010 | Cell Phones
My phone was working at night, I plugged it into the wall charger while it was still on. I woke up the next morning, disconnected it from the wall charger, and the phone immediately shut off. I plugged it...
Dear Anthony,
It seems that over charging has damaged your gadget's motherboard or battery mechanism. You have to get it serviced. But still you can try by Removing your battery for 1 hr and then after re insert.
Jun 06, 2010 | RIM BlackBerry Pearl 8100
I shut down my desktop properly that night.i woke
First use the following steps:
Turn off the system and disconnect power cables.
Press and hold the power button for 30 seconds
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to turn off the system,
Disconnect power cables
Open the case and re-seat memory modules.
If you have more than one modules installed, test the system with a single module at a time.
Thanks
Feb 19, 2010 | Acer Computers & Internet
My phone battery died, and I plugged it into the charger over night, and when I woke up in the morning it didn't charge it any. I tried a different outlet, and it still didn't charge.
actually the batteries should not be over charged..
once the charge is full you should stop charging it more..
it you leave it over-night the battery will lose its back-up
you should try a new battery..
Jul 13, 2008 | Samsung Lands Phones
Can't hear anything
fuck same help shoud i disassemble it
Jan 18, 2008 | Sony Ericsson W300 Cellular Phone
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
RIM BlackBerry Bold 9000 Smartphone Logo
83 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
