Question about Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player
My Ipod touch will only turn on when plugged into the wall or the car charger. When connected to the computer the apple logo flashes on and off but will not do anything.
  • 600 Answers
Do this...
While connected to a power source, try to reset the iPod touch. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged. if still doesnt power on try this.. Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
    • If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
  3. While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
    Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.My Ipod touch will only turn on when plugged into - ht1808_01.jpg
  4. Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:
  5. If necessary, open iTunes. You should see thMy Ipod touch will only turn on when plugged into - ht1808_02.jpgrecovery mode" alert:
  6. Use iTunes to restore the device.
also maybe your unit have been in contact with liquid You can tell if the headphone-jack Liquid Contact Indicator has been triggered by looking directly down into the headphone jack. Use a lighted magnifying glass or angle the iPhone or iPod so light shines down into the headphone jack. At the base of the headphone jack, you should see what is normally a white or silver-colored dot. The dot will become full or half red or pink when the dot has come in contact with water or a liquid containing water. To view the dock-connector indicator on iPhone 3G or iPhone 3GS, use a lighted magnifying glass and hold the device so that you can view the center bottom of the dock-connector housing. A full or partial red dot will appear if the indicator has been triggered.
a feedback would be much appreciated
Posted on Jun 06, 2010
My ipod wont turn on help me it worked for a min then it turned off
  1. Try plugging your iPod into your computer or into a wall charger. After a few hours, try using it without it being connected to the charger.
  2. If your device is less than a year old, go to the Apple Store and they may be able to replace it for free on the spot as part of the warranty.
  3. If your device is older, you can go to the Apple Store and have them repair it for free
  4. You can go to the Apple Store with your iPod, and buy a new one for 10% off.
Mar 10, 2011 | Apple iPod touch
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
I plug my i pod touch 3rg gen. intothe computer and it stays connected for about 15 seconds then disconnects... its not the cord i used multiple... and it charges fine on a wall charger... help!!??!!
try resetting ipod.
To reset your iPod:
· 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
· 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
· If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
· If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 01, 2011 | Computers & Internet
How do I charge my new iphone 16GB?
Your new iPhone comes with a USB cable and a wall charger in the box. If you don't have a computer, you can plug the wall charger to any socket in your house and connect your iPhone to the wall charger using the USB cable. However, if you have a computer, you can plug the USB cable to any USB slot from your computer and connect it to your iPhone.
You can also charge your device from any iPhone dock, or even those docks attached to your home theater system.
For more iPhone / iPod touch tips, click here.
Feb 12, 2010 | Apple iPhone (16 GB) Smartphone
Ipod doesnt work
I think I know just the problem. The connection cord that came with the wall outlet charger can only be used for charging. You have to have the original apple cord in order for the computer to recognize it.
I had the same problem.
Sep 20, 2009 | Apple iPod touch
The i pod is not showing that it is charging
Since it has been sitting for so long, try doing this: Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge just enough so that it can sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, charging. It should work after letting it sit plugged up to the computer.
Dec 30, 2008 | Apple iPod nano
80GB video ipod is not turning on.instead the apple symbol blinks
Dec 19, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod Does Nothing When I Plug It into my computer.
you have to get another usb connecter not the wall charger cable
Nov 25, 2008 | Apple iPod touch
Apple screen
Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge normally, just enough so that it can come on and sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, wait few minutes, charging. It should work after letting it sit plugged up to the computer.
Oct 17, 2008 | Apple iPod nano
Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player Logo
2,084 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
