Question about NetGear RangeMax WPN824 Router
How can I set up NETGEAR WPN824 v2
I need information about how I can activate ir have been off for 6 month
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
All you need to do is follow the steps below.
1. plug in a computer to one of the LAN ports on the WPN824
2. plug in your modem to the WAN or internet port on the WPN824
3. Turn on your netgear box.
4. Wait for the power light to get steady.
5. Go to your computer. Open internet browser and type http://routerlogin.com .
6. username is admin , password is password. If the default account details didnt work. reset the router for 30 secs and then try again the username and password.
7. go to basic settings. Here you will setup the internet on your router, it depends to your ISP.
If you can go this page, that means your router is still working .
Posted on Jul 03, 2010
My bajaj pulsar 135 cc over flow from carbs pipe ocassionally while running. Same problem occur 6 months ago i changed the needle valve which is fitted in carbs. should i change it again or not .
Hi, Mayur and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue please visit the websites below. Good luck and have nice a day.
How to rebuild your Chinese scooter carburetor
GY6 Carburetor Removal Inspection Adjustment START TO FINI DOWNLOAD Bajaj Pulsar 135
http://www.marutibajaj.com/pdf/PULSAR%20135%20LS%20SPC%20.pdf
http://shahriary.staffcms.um.ac.ir/imagesm/1064/My_Pic/pulsar_135_ls.pdf
May 22, 2012 | 2010 Bajaj Pulsar 135 DTSi
Cannot re-register Vertus Fluid Mask software, which I already own
Hi aaliceronm,
Please follow the instructions below on how to register/activate your Vertus Fluid Mask software.
Vertus Tech provides two ways of registration/activation:
Fluid Mask 2.0: In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three months).
Fluid Mask 3.0: For Fluid Mask 3 they offer two ways of registration and activation of your full Fluid Mask license:
Online registration:
This option requires an active internet connection on the machine on which you are installing Fluid Mask.
1. If you already installed the trial version of Fluid Mask please open Fluid Mask and go to > Help > Register.
2. Fill out the registration form and insert your serial key. The serial key should have been sent to after you placed your order for Fluid Mask 3 and has the format
01AXYZB0B123F123CDA7121234567AF123
Please make sure you copy/paste the serial key into the serial key field to avoid typos or mixing up digits and letters like 0 and O etc.
3. Click on the button to send the information.
4. The registration takes a few seconds. If it was successful you will see a pop-up window confirming that you are now registered.
5. You can either copy and paste your information from there into a file or to create an e-mail.
6. In addition you can see the message "You have a full license" when going to > Help > About Fluid Mask.
Registration by e-mail:
3. Click on the button to send the information. The registration takes a few seconds.
4. If Fluid Mask cannot detect an active internet connection or could not complete the registration for other technical reasons, then Fluid Mask will display your registration information in a new window.
6. Please send the complete information displayed to registration@vertustech.com. It is important that the information we receive is complete and correct.
They will process your registration as soon as possible and provide you with a license code by e-mail. You can then use this license code to activate your full Fluid Mask license under > Help > Register in Fluid Mask 3.
^return to top
Do I need an active internet connection?
Fluid Mask 2.0:
In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three month).
Fluid Mask 3:
Fluid Mask 3 does offer an online activation. For those users who don't want to connect their workstation where Fluid Mask is installed to the internet we offer an activation by e-mail, too. Instructions are displayed in the software during the registration process.
Hope it helps.
Thank you for using FixYa.
Jun 30, 2011 | Computers & Internet
Samsung ua46c8000 tv ir/sensor dose not work
Good day!
Please follow this procedure to find the exact problem.
  1. Check the battery of the remote.If your battery is 1.5vdc x2,the reading should be 1.5vdc x2 also! or 1.4vdc,tolerance to response the remote.Replace the battery if it is below on the tolerance voltage.
  2. Check the IR sensor using a digital camera or cell phone camera.
  3. Place the camera in the front of IR sensor then push any of the button to activate the remote.If your IR sensor flashes on the camera it means you IR sensor is good if not flashes on the camera replace it.
I hope this information will be helpful.Thank you very much.
Apr 18, 2011 | Samsung Bn59-01041a Remote Control
NEW SAMSUNG CABLE BOX TIME WARNER &TIVO SERIES 2
the IR is located next to the power button and you will have to select pioneer as your cable box brand and it will work fine
Jul 28, 2010 | Samsung Televison & Video
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
What is the firing order for a mercedes e 420 4.2 liter??
I joined this site in NOV09 providing free answers. This site has had an explosion (+55%) of activity since joining 4-months ago.
Although you may not need this information anymore, I am going back and answering questions that were never answered.
Again my sincerest apologies....
For the 4.2L
Firing Order:
1-5-4-8-6-3-7-2
Cylinders:
(back of engine)
4-----------8
3-----------7
2-----------6
1-----------5
(front of engine)
Sep 30, 2009 | 1997 Mercedes-Benz E-Class
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
Excel support
Cool problem I use this to track stocks for the latest 5 days, 15 days and so on.
First I have a sheet that is titled "DataRecord" this has my individual data in columns and the days recorded in rows. This is a complete record or all recorded stock activity. This is where all the entrys are made in rows. I freeze window to make the column headings and the left most column(the date) always visible to prevent errors.
Next I have a sheet that is titled "L5DaysData' I have sevreral rows of data like avg, & what ever. and the latest 5 days data starts on line say 6. a typ. cell ='DataRecord'!B970
The next cell down has a value of ='DataRecord'!B971 and so and on until B974
My Graphs are built on these individual "L5 or 15 or 60 or90 day" sheets of data.
Next I make a macro that translates the last line of data down one row and deletes the row just above the earliest that I want to save on "L5DaysData" so it always shows only the latest 5 days of information.
All the information shown on that worksheet is the data for graphs or tables refering to the latest 5 days activity.
The graphs are automatically updated with the data each time the macro is run.
You can also use a formula to adjust the date column by adding a value of one to a specfic dated cell untill you reach Sat or Sun and add 3 or 2 to that date cell and translate that down a column and use a work sheet that records only the latest 3Mo. with macros that updates the information when you want it to.
Hope this helps.
Glad to be of assistance - please rate the solution I can learn from you. Thanks
Oct 24, 2008 | Microsoft Office 2003 Basic Edition...
NetGear RangeMax WPN824 Router Logo
119 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
