Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Husky 55 rancher - I rebuilt this saw but now it won't start. Seems like not getting enough gas. What should I check for?
    Brigadier General:
  • 4,088 Answers
Check for plugged fuel filter and muffler. Check the fuel lines for decay or damage. Did you service the carburetor? Make sure the lower chamber diaphragm is not hard or cracked. Did you change the two jet settings? Put some fuel mix into the plug hole and pull it through--you should get a pop or two. If ok, then concentrate on the fuel problem. If no spark at the plug, check the ignition module gap to the flywheel magnets using a thin business card for a gauge. Hope this helps!
Posted on Jun 17, 2010
I want to buy a 16" 3/8 Husky bar that fits the 55 Rancher to replace my 20" bar on my Poulan Pro 5020av...where can I get it?
as long as your 5020av has a 3/8 sprocket it will work they make a professional landowner and homeowner for these saws each costing different prices tell the dearler what your doing and he can decide what you need
Dec 10, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
Mar 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a Husky 55 Rancher, was sawing a tree and
Yes. this checks both. Change the plug first <$5 plug >$50 coil.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Ignition module gap
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Husqvarna Garden
I have a rancher 55 and I had to reconnect the gas line to the carburator and now I can't reconnect the throttle I need a view of the throttle assembley. Where can I find one thank you
55 IPLs start at page 4 but I doubt it has the level of detail you need.
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
I suggest you go here and join.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
The following thread is about your saw. Someone of will probably be willing to provide the photo you need. There are other threads where your saw is discussed.
http://www.arboristsite.com/showthread.php?t=122545&highlight=55+rancher
I must warn you. Many that frequent here develop an obsession with chainsaws. When I joined I had 1 and had only owned 2. I now own 7 and am always on the look out for a new one.
Good luck with your project. HTH
Lou
Feb 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna chain saw rancher 55
Try this get back to us with the results.
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 02, 2009 | Husqvarna Chain Saw 20" Bar
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky 350 leaking gas from white plug in gas tank
I have a rancher 55 and it was leaking gas, i replaced the gas cap. That solved the problem.
Sep 30, 2008 | Garden
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
351 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
