Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Dishwater won't drain
After washing a load of dishes, the bottom drawer still contains about 2 inches of water. Attempts to blow air back through the drain hoses doesn't dislodge any material or allow air to freely flow.
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherDishwater won't drain - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 07, 2010
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
Aug 14, 2011 | Dishwashers
I have a single draw F&P Dishwasher and get the error F1, turned off the power and still same problem, but in the last 2 or 3 loads of washing dishes not all the water has been gone, always about 2cm...
most likely you have a leaky drain hose.
Have you checked if sink drain is clear (no back flow)
Turn dishwasher power off.
Empty all the water using a small container and towels.
Get the drawer out (remove front cover first by taking the side pins out and carefully lifting it).
Check behind to see water lying on the floor of dishwasher housing. If leaky drain hose you will have to replace it.
Dry the base of the dishwasher (towels and dryer) otherwise F1 will not go away.
Sep 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kitchenaid 2 drawer dishwasher beeping
its saying its flooded allow a few days and it will go away then fill and drain then fill and drain till all soap is gone
Jun 04, 2010 | KitchenAid KUDD01DSSS Built-in Dishwasher
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water in top drawer
I am not a repairman but have installed several duel drawer dishwashers. Most dishwashers have a check valve preventing backflow. Water under pressure will always follow the path of least resistance and in your case it is going into the upper drawer. Be sure the drain is open and flowing easily under your sink whether that be the disposal or a TEE. It may help if the drain line is elevated as high as it can go under the sink just before it reaches the drain. How often do you use the top drawer? Perhaps run a cycle on the hottest cycle without dishes to attemt to clean or force through any contaminants in the check valve through into the drain. Hope this helps, Ken
May 01, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Inch of water left in bottom of dishwater after done running
check for blockage starting at air gap and disposer.trace back and clean
Dec 31, 2008 | Frigidaire 24 in. FDB635RF Built-in...
On TCD18PAD BWW refrig with freezer (drawer, not door) on bottom, water accummulates in bottom of freezer and freezes into ice which some how thaws with water flowing out bottom of drawer door onto kitchen...
You have a clogged defrost drain tube. On the back of the refrigerator in the center, about two feet above the floor, is a 7 inch by 7 inch square steel cover held on by four screws, one at each corner. The defrost drain tube emerges from the bottom of this cover and terminates loose in the drain pan below the refrigerator. Remove the cover. Underneath is the plastic defrost drain tube fixture, which is held by two screws. Remove the screws and take off the drain tube fixture. This fixtue is clogged. Run hot water and dish detergent through it and blow through it at the big end to remove the clog. Reassemble. That's it. You don't have to take the refrigerator apart. One caution. When the refrigerator has a clogged drain tube, the defrost water will back up and freeze around it. So you may need to empty your freezer and unplug the refrigerator for eight hours or so first before you perform this procedure to allow all the ice around the clogged drain fixture to melt.
Aug 31, 2008 | GE Refrigerators
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
144 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
