Question about Whirlpool GS6NBEXR Side by Side Refrigerator
14 year old whirlpoolside by side freezer side not coolingbad thermostat??
  • Robert Moller
    Robert Moller Jun 06, 2010
    Possible but more info needed.
  • 15,935 Answers
It appears your thermostat has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
Fridge is warm with no cold air.
Unless there are 2 thermostats, one for freezer and one for refrig, it's not the thermostat if the freezer is ok. Sounds like the small fan that blows the cold air from freezer into refrig is not operating.
Jul 23, 2010 | Refrigerators
Has stopped cooling
IF THE FREZERWORKS THE ISSUE IS THE SETING FOR THE AIRFLOW BETWEEN THE FREEZER AND REFER BOX IS SET TO MAX COLD FREEZER, IT HAPPENS MORE THAN YOU WOULD THINK! IF IT SEEMS WARM, RATHER THAN SETTING THE THERMOSTAT TO COLDER THEY ALSO PEG THE OTHER CONTROL THAT DOES NOT CONTROL THE COMPRESSOR AT ALL IT SIMPLY OPENS A FLAPPER TRAP DOOR AJAR OR WIDE OPEN OR IF SET TO MAX COLD IT CLOSES OFF THE REEFER!! AND KEEPS THE COLD IN THE FREEZER BOX, IF THE FREEZER WORKS ITS FINE !
Apr 23, 2010 | GE Profile PSS26NGS Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
GE GSS25LGM freezer not working. It's about 8
it seems like the thermostat on the freezer side is not function right but does the motor of the freezer run or not if not check thermostat
May 16, 2009 | GE GSS25LGM Side by Side Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Compressor and fan work on cendenser, evaporater works, but the fan on the evaporater in the freezer rear cuts off after the initial run cycle. The coils then freeze. What are your suggestions replace...
Probably a bad defrost thermostat. The fan motor power runs through the defrost thermostat then to the fan motor.If the defrost thermostat is opening too soon, you get no fan and no defrost.
Yes you can replace this part yourself.
May 03, 2009 | Amana 25.9 cu. ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
48 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
