Question about Whirlpool 24 in. DU1050SS Built-in Dishwasher
The "clean" light blinks
I have a DU1050 and the "clean" light was blinking and it would not start a new wash cycle.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
Clean light blinks constantly
press heated dry
press normal wash
press heated dry again
press normal wash again..........
.....wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Feb 05, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool 24 in. DU1050SS Built-in Dishwasher Logo
328 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
