I have a vizio jv50p. The tv turns on but won't display a picture for me. I need to know what the common problem is for this particular symptom. I can order what-ever part it needs. I know it's a common issue with the set and need some input on what is the common failing component in this set. Please do not reply for assistance if you haven't repaired these before. I will just ignore the comment and move to the next tech with the answer. Thanks.
  • 505 Answers
I'm pretty sure its the bad capacitors on the power supply board. They will look like this :
A good cap is totally flat on the top.
Anyways, many of these vizio TVs had bad caps from the factory and they took about 2 years to fail. If you read the values off the side of them and replace them with the exact same values (example 1000uf @ 25volt) then it should work good again.
You can purchase higher voltage caps, but make sure you get the 105 degree versions, and keep the uF rating the same.
Use a company like www.mouser.com, www.mcmelectronics.com, or www.jameco.com to get your caps, and you'll need a soldering iron, desoldering wick, and some solder to complete the job.
You can also complain to vizio and they might help you out. In my experience, they just send out a tech with another power board, same "potentially bad" caps on the new board.
Let me know how I can be of further assitance to you.
Posted on Jun 06, 2010
  • 5 more comments
  • thielectronick
    thielectronick Jun 06, 2010
    oh, the power board is the one in the middle
    the power from the wall (AC power) goes straight into it and wires go to all the other boards.
    If the caps look good, I can talk you through narrowing it down to whichever board it may be, but I'm almost positive this one had some bad caps. If you see other "same value" caps that aren't bulged, replace those too. Only some values were defective, but you can assume any value that is bulged will go bad, even if other ones look good.
  • Steve Yelmene
    Steve Yelmene Jun 06, 2010
    I see nothing to that effect. The owner told me that the set made a sizzling noise before it went out.
  • thielectronick
    ok, if the caps are good, then you are typically narrowing down if you have a Y-sustain failure or Z-sustain failure. If you have the power LED, power is likely ok. If its turning on, the microprocessor is responding to your command and kick it on, so your main board is likely ok.
    at this point, you need a mulitmeter to check the fuses on the Y or Z board.
    the power board powers these boards with a Vs and Va voltages, which are about 200 and 60 volts respectively.
    if one of these voltages does not come up, you can isolate which board is shorted or "pulling down" the power supply by unloading the voltage cables.
    **important - this tv has a switch mode power supply (smps) that needs a load to work, if you unload both the Y and Z boards it will blow up the power supply because there will be no load. some will have the power cables going to both boards independently, others will have them "daisy chained" and you can really only unload one of them.
    anyways, you likely have a bad y or z board.
    this tv has multiple plasma panel manufacturers, usually lg but sometimes it will be a samsung
    on the lg, the part #s are listed on the boards
    from the back of the tv. the Y board is the one on the left with all the little buffer chips driving the rows of the picture (lots of wires) and the Z board is the one on the right with the large copper ribbons (2-3 big fat wires) that just sustain the panel.
    let me know where i can be of assistance.
  • Steve Yelmene
    Yes, LG is the manufacturer. Is there something I can test to isolate which board is the problem?
  • thielectronick
    yes
    use an ohm meter and monitor Vs to cold ground
    if its low ohms, you have a short. unplug the cables and see which board has the "low ohm" condition
    if its high ohms, try the same check on the Va line, but thats more rare
    typically there are fuses on each board, check those with an ohm meter, whichever has a blown fuse is likely your bad board.
    if its the Y sustain, make sure all the buffer ICs look ok, the little chips that run the horizontal rows of the picture, if one has a pin hole burned into it, it will blow out your new Y sustain board if you don't replace both parts together.
  • Steve Yelmene
    Do you possibly have a service manual for the tv? Or, do you know where I can get one. I would like to get one for free.
  • thielectronick
    thielectronick Jun 07, 2010
    contact vizio
    877.698.4946
Vizio TV won't work. We get sound but picture is like distorted and now it won't show video
There are lots of common problems with flat screens that result in those symptoms. Some fixes are super easy and cost $.35 haha and others can cost hundreds not to mention if your doing it your self or not factor in labor. Lots of people sell tv s like that from $50 to $100 bucks and they sell quick! Hell I'd buy it if I had the chance. Could use parts or god forbid find an easy solution ( rare :( )
Mar 13, 2013 | Televison & Video
Picture but no sound
the loud pop was a capacitor or a resistor popping, it will need replacing.
Jun 19, 2017 | Vizio JV50P 50 in. Plasma TV
Need service manual for vizio JV50P HDTV10A
Hi Mike,
Please click the link below to view and saved the pdf file format of Vizio JV50P HDTV10A Service manual.
Click HERE.
Please let me know if you have a hard time downloading the manual, I will send it to you through email.
Ratings and feedback are highly appreciated.
Good luck and take care.
Jdvillanueva
Nov 15, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio JV50P, Made a popping sound, the set remains on with no picture.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 03, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
Heard a pop and the picture and sound went off. The light on the front still eluminates when you try to turn it on but nothing else. Vizio JV50P
A very common problem with that model is the power supply board, if you remove the back you probably will find a couple of bulged or the top blown off, electrolytic caps, that need replace, or just replace the power supply. You can check at www.partstore.com for a power supply.
Feb 11, 2011 | Vizio JV50P 50 in. Plasma TV
When I turn on the TV with the remote first thing in the morning I get sound but no picture. I leave the TV on with the sound on for 30 minutes and than begin to turn it off and on till I get a picture...
does the screen look lit at all? you may have an issue with the sustainer boards (Y and Z). without taking voltage readings at the power supply board it will be hard to tell. if you check, there may be bulging capasitors on the power supply board. if so, that will need to be replaced. you can contact hdrepair for a diagnosis and repair.
Nov 20, 2010 | Vizio JV50P 50 in. Plasma TV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
