Question about Gear Head WC755IPT Webcam
The microphone does not have a high volume.
When i use skype the other person can't hear what I'm saying because of my microphone.
  • Gear Head Master
  • 2,879 Answers
Set up your audio
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to Skype
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Posted on Jun 06, 2010
The sound card of my emachine E725 is not working
You may want to adjust the mic volume on the settings of your microphone as it would seem skype loves to auto adjust and turn it all the way up to where the mic no longer hears you. So just set it down as far as you can go and then do this each time that skype blasts the volume of your mic.
Oct 25, 2012 | Computers & Internet
Other person cannot hear me
Have you checked to see if you microphone is muted? Go on control panel, then Hardware and Sound, then Sound, then manage audio devices. Go on recording, click microphone, then levels and if it is not on high volume drag it so it is, the click ok. If it was muted, then this should have fixed the problem.
Oct 02, 2012 | Skype IM
The person I am speaking with does not hear me. The microphone function does not appear to be working. I have adjusted the volume and that's not the problem. I have plugged both jacks (microphone and...
The person I am speaking with does not hear me (He is deaf).
The microphone function does not appear to be working. I have adjusted the volume and that's not the problem (You must speak as well).
I have plugged both jacks (microphone and speaker) into my PC hard drive and am using my PC to talk on Skype (You cant plug even a single jack in the hard drive).
Problem solved!
Apr 14, 2010 | Logitech (980361-0403) Headphones
Where is the built-in microphone.No one can hear me on Skype, yet it says microphone volume is low onscreen and I reset to high, but it still reads LOW
Microphone should be located on the lid of laptop above the screen by the latch release button. You will see a small rectangular hole (if you have a built-in webcam it is to the left of it)
Jan 16, 2010 | Toshiba (P000257700) Microphone
Everything works except the person I call cannot hear me. I am using skype. The echo check on skype works, I have tried two other cameras and I have the same problem. No matter how I change the settings...
The Camera and Audio setups are unrelated in both Windows and Skype. Please check your Windows Audio devices volume settings and specifically the Microphone settings: it appears to be disabled or the volume level set much too low. The windows settings overrides the settings in Skype (or in other words, Skype volume settings are a subset of the Windows volume settings). Check that Skype audio is setup properly after starting Skype: Tools -> Options -> Audio Settings -> select your required devices and volume levels. During this ajustment process, make free calls to Skype 'Echo / Sound Test Services".
Hope it helps! Let me know how you go!
Dec 31, 2009 | Microsoft LifeCam VX-5500 Webcam
My computer says the microphone is working but skype says no
how about the speakers working? if working your speaker it means the microphone has problem, ( hardware problem,, did you try to change the setting on the property?
Sep 06, 2009 | Toshiba Satellite P105-S6104 Notebook
I can hear the other person but they can't hear me
Well in SKype as i remember u have to select a Video device and a Microphone.. make sure u have the same camera selected for sound as well as for video
Aug 11, 2009 | Logitech Quickcam Chat Webcam
I can hear the other party but I can't hear them. it says that my mic is mute....how do I undo this?
You mean "I can hear the other party but they cant hear me"
Skype probably didnt change your microphone.
Go to Skype Tools>Options>General>Audio Settings and on the Microphone dropdown menu, make sure your headset is selected. If it's installed correctly and you talk into it, you should see the volume bar start moving. Click save and start talking!
This is assuming you've already gone into sound proporties in windows and made your headset the default microphone and checked the volume settings on it.
Feb 19, 2009 | Skype IM
Skype not working
your microphone is either broken or muted. check recording volume controls
Jan 10, 2009 | Skype IM
Gear Head WC755IPT Webcam Logo
85 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
